方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Laser Doppler anemometry (LDA) is a widely used flow measurement technique for detecting flow velocity (see e.g. Albrecht et al. 2003). In addition to velocity also particle position measurements were performed with an extended LDA (Shirai et al. 2008). In the present work another extension is proposed. It is able to determine the velocity component parallel to the wall with spatial resolution near a reflecting wall. In contrast to imaging near-wall measurement techniques with mirrors (Kunze et al. 2008), the proposed sensor is not limited by pixel resolution or diffraction.
如何保护好你的CCD相机——PIV必读
水生生物触须后的流场研究
围绕窄圆柱的低雷诺数流体的三维影响
