方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
In the present investigation, Laser Induced Plasma Spectroscopy (LIPS) is performed with an original two dimensional approach. The spectrometer usually used to record light emission from plasma and compare well-chosen peak intensity is here replaced by two intensified cameras equipped with band pass filters. The ratio of emission intensities recorded with the two cameras at two different wavelengths provides the concentration of identified species in given mixtures. This technique gives information on mixture composition on the whole plasma volume increasing both the spatial resolution and the probe volume of the measurement. Tests are performed on coaxial jets of air and nitrogen showing the ability of the method to catch the mixing layer developed at the nozzle exit.
如何保护好你的CCD相机——PIV必读
水生生物触须后的流场研究
围绕窄圆柱的低雷诺数流体的三维影响
