方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Experiments were conducted to investigate transfer of heat and momentum of fluid flowing through horizontal micro-channels with square cross section (Dh= 195 and 522μm) and 100mm length. The flow was set up by a syringe pump in borosilicate glass tubes heated by an electrical conductive transparent film of InOx deposited in the channel outer wall, which allowed establish a constant axially and longitudinally uniform heat flux boundary layer at the same time that it provided optical access to the inner flow.
如何保护好你的CCD相机——PIV必读
水生生物触须后的流场研究
围绕窄圆柱的低雷诺数流体的三维影响
