方案下载应用领域 | 制药/生物制药 |
检测样本 | 化药新药研发 |
检测项目 | 其他>方法开发 |
参考标准 | GB/T 8**** |
Three highly fluorescent dilactone bridged terphenyls with crankshaft architectures have been synthesized.This general class of compounds is relatively unexplored. These compounds have been characterizedby fluorescence and UVevis spectroscopy. For all three compounds, a direct correlation between the rigidity of the terphenyl system and the strength of absorption and emission of light has been observed. Preliminary studies have indicated that compounds with this architecture have the potential to be useful as pH-driven molecular switches and/or sensors with instant fluorescence attenuation at high pH values.
优选 KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
型号:Customized NanoProducers优选 KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
型号: IJM SingleCore NanoProducer优选 KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
型号:IJM NanoScaler优选 KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
型号:IJM DuoCore NanoProducer耐士科技:使用Biotage Isolera快速纯化液相制备色谱从库拉索芦荟叶皮提取天然的磷酸二酯酶抑制剂by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成大麻素及其代谢产物的定量半定量测定by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成烷基羟基代谢物的定量半定量测定by耐士科技
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
