方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract The fat content of spices poses problems of temperature rise and sieve clogging during grinding. Due to this temperature rise, spices lose a signi®cant fraction of their volatile oil or ˉavouring components. Therefore, a cryogenic grinding system was designed and developed to cool the spices before feeding to the grinder and also maintain the cryogenic temperature in the grinding zone. The main components of the cryogenic grinding system are a precooler and grinder. The precooler consists of a screw conveyor assembly, a compressor, a liquid nitrogen dewar and power transmission unit. The design considerations, calculations and development of the precooler have been discussed in the paper. A commercially available grinder was adopted for this purpose. The tests conducted on grinding of cumin seed revealed that it could be successfully ground below the temperature of ÿ70°C. Above this temperature, sieve clogging took place. The increase in grinding temperature fromÿ160°C toÿ70°C resulted in a signi®cant increase in particle size of the product and speci®c energy consumption in grinding. A variation in volatile oil content was obtained in the range of 3.30±3.26 ml/100 g with increasing temperature from ÿ160°C to ÿ70°C, but this variation was found to be non-signi®cant at 5% level. ó 1999 Elsevier Science Ltd. All rights reserved
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
