方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract Tumor necrosis factor (TNF)-α is produced by cells of the immune system and is a key mediator in immune and inflammatory reactions. Through interaction with widely expressed receptors (TNF receptor 1 and TNF receptor 2), TNF-α is able to orchestrate the expression of a range of downstream proinflammatory molecules. Over the past decade novel biologics that inhibit TNF-α have been developed as extremely effective treatments for rheumatoid arthritis. Structurally, these biologics are antibodies, or TNF receptors on an antibody backbone that bind TNF-α directly and are delivered to patients by repeated injection. Gene therapy offers an improved approach to delivering biologics as a single administration of their encoding genetic material. In the present study we demonstrate the therapeutic effect of a small molecular weight dimeric TNF receptor 2 (dTNFR) constitutively expressed from plasmid DNA, delivered intramuscularly with electroporation, after disease onset in a collagen-induced arthritis model. Regulated promoters that enable the production of a transgene to be controlled are more suited to the application of gene therapy in the clinic. Regulated expression of dTNFR from the plasmid pGTRTT was also therapeutic in the mouse collagen-induced arthritis model when the inducer doxycycline was also administered, whereas no therapeutic effect was observed in the absence of doxycycline. The therapeutic effect of dTNFR expressed from a constitutive or regulated plasmid was dependent on the degree of disease activity at the time of DNA injection. The observations of this study are considered with regard to the disease model, the magnitude of gene regulation, and the path to clinical application. Keywords: arthritis, doxycycline, gene therapy, regulated expression, tumour necrosis factor-α
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
