方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract Using the Agilent G1888 Network Headspace/6890N GC/5975 inert MSD system several primary packaging materials for pharmaceuticals were evaluated in a study. In this Application Note results for two of these materials, a labeled HDPE bottle and a soft elastomer liner from the inside of the screw cap are presented. A multiple headspace extraction technique (MHE) was used and the highest attainable amount of extractables that could ever be concentrated in the drug product was calculated. Further, the extraction efficiency of the MHE procedure was studied using benzaldehyde and phenol as target compounds. The analytical results obtained from the inert 5975 headspace-GC/MS provide excellent sensitivity when utilizing SIM/Scan data acquisition with multiple headspace extraction (MHE). The synchronous SIM/Scan feature of the 5975 MSD allows for very low level SIM detection while also searching for unkowns using scan data.
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
