方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Glass bead/x-ray fluorescence spectrometry of the sludge incineration ashes generated in sewage processing was developed for the determination of ten major components (Na2O, MgO, Al2O3, SiO2, P2O5, K2O, CaO, TiO2, MnO, Fe2O3) and five minor elements (Zn, Cu, Cr, As, Pb). Sewage sludge ashes consisted of rockforming minerals and phosphate crystals that had been used for phosphorus removal. Ash samples were melted and molded with lithium tetraborate to 35 mm diameter glass disks in a Pt–Au crucible. Analytical results of ten major components and five minor elements agreed well with the recommended values of a phosphate rock standard reference material (NIST SRM 694). Elemental compositions of sewage sludge ash from seven sewage-processing plants in Japan were determined using this method. Concentrations of Fe2O3, SiO2, and CaO, along with loss of ignition in sewage sludge ash mutually differed among the sewage-processing plant products. Seasonal variations in concentrations of ten major components and five minor components of ash samples produced from October 2001 to September 2002 were determined using the proposed method. Concentrations of SiO2increased with the inflow of gravel by rainfall, thereby decreasing concentrations of P2O5 originating from excreta and microorganisms. Copyright 2008 John Wiley & Sons, Ltd.
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
