方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The 8-correction approach has great advantages: it takes the best from the numerical correction methods, and leaves behind most of their inconveniences; it is simple to apply and very accurate; it is particularly well suited to the analysis of industrial products where composition variations are usually not very large. The authors believe that the 8 method will be in common use in the near future. A paper on the analysis of cements appears in this Journal (11); although that paper is not intended to be a typical example of application of the 6 method, it nevertheless shows that the method offers definite advantages in relation with accuracy and simplicity.
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
