型号 | HI 83200 | |||
测量参数 | 量程 | 方法 | 试剂代码 | |
铝 | 0.00 to 1.00 mg/l Al | 试铝灵法 | HI93712-01 | |
砷 | 0.005 to 0.5 mg/L | Comparision | AF470 | |
总碱度 | 0 to 500 mg/l CaCO3 | 比色法 | HI93755-01 | |
氨氮MR | 0.00 to10.00 mg/L NH3-N | Nessler | HI93715-01 | |
氨氮LR | 0.00 to 3.00 mg/L NH3-N | Nessler | HI93700-01 | |
溴 | 0.00 to 8.00 mg/l Br | DPD | HI93716-01 | |
钙硬度 | 0 to 400 mg/l Ca CO3 | 比色法 | HI937521-01 | |
二氧化氯 | 0.00 to 2.00 mg/l ClO2 | 氯酚红法 | HI93738-01 | |
余氯 | 0.00 to 2.50mg/l Cl2 | DPD | HI93701-01 | |
总氯 | 0.00 to 3.50mg/LCl2 | DPD | HI93711-01 | |
六价铬-HR | 0 to 1000 μg/l Cr6+ | 联苯碳基酰肼法 | HI93723-01 | |
六价铬-LR | 0 to 300 μg/l Cr6+ | 联苯碳基酰肼法 | HI93749-01 | |
铂钴色度 | 0 to 500 PCU | --------- | -------- | |
铜HR | 0.00 to 5.00 mg/l Cu | bicinchoninate | HI93702-01 | |
铜-LR | 0 to 1000μg/l Cu | bicinchoninate | HI95747-01 | |
联氨 | 0 to 400 μg/l N2H4 | 浊度比色法 | HI93704-01 | |
铁-HR | 0.00 to 5.00 mg/l Fe | 邻菲罗琳法 | HI93721-01 | |
铁-LR | 0 to 400 μg/l Fe | TPTZ | HI93746-01 | |
氰化物 | 0.000 to 0.200 mg/l CN | PyridinePyrazalone | HI93714-01 | |
氰尿酸 | 0 to 80 mg/l CN | 浊度比色法 | HI93722-01 | |
氟化物 | 0.00 to 2.00 mg/l F | SPADNS | HI93729-01 | |
钙硬度 | 0.00 to 2.70 mg/l Ca | Calmagite | HI93720-01 | |
镁硬度 | 0.00 to 2.00 mg/l Mg | EDTA法 | HI93719-01 | |
联氨 | 0 to 400 μg/l N2H4 | P-D法 | HI93704-01 | |
碘 | 0.0 to 12.5 mg/l I | DPD | HI93718-01 | |
镁硬度 | 0 to 150mg/l MgCO3 | 比色法 | HI937520-01 | |
锰- HR | 0.0 to 20.0mg/l Mn | 高碘酸盐氧化法 | HI93709-01 | |
锰- LR | 0 to 300 μg/l Mn | PAN | HI93748-01 | |
钼 | 0.0 to 40.0mg/l Mo | 氢硫基酸法 | HI93730-01 | |
镍-HR | 0.00 to 7.00g/l Ni | 光度法 | HI93726-01 | |
镍-LR | 0.000 to 1.000mg/l Ni | PAN | HI93740-01 | |
亚硝酸盐氮LR | 0.00 to 0.35mg/l NO2-N | 叠氮比色法 | HI93707-01 | |
亚硝酸盐氮HR | 0 to 150 mg/l NO2-N | 硫酸亚铁法 | HI93708-01 | |
硝酸盐氮 | 0.0 to 30.0mg/l NO3-N | 镉法 | HI93728-01 | |
溶解氧 | 0.0 to 10.0 mg/l O2 | Winker法 | HI93732-01 | |
臭氧 | 0.00 to 2.00 mg/l O3 | 比色法 | HI93757-01 | |
酸度(pH) | 6.5 to 8.5 pH | 酚红法 | HI93710-01 | |
磷酸盐- HR | 0.0 to 30.0 mg/l PO4 | 氨基酸法 | HI93717-01 | |
磷酸盐- LR | 0.00 to 2.50mg/l PO4 | 抗坏血酸法 | HI93713-01 | |
磷 | 0.0 to 15.0mg/l P | 氨基酸法 | HI93706-01 | |
钾-HR | 20 to 200mg/l K | 浊度比色法 | HI93750-01 | |
钾-MR | 10 to 100mg/l K | 浊度比色法 | HI93750-01 | |
二氧化硅 | 0.00 to 2.00mg/l SiO2 | 杂多蓝法 | HI93705-01 | |
银 | 0.000 to 1.000mg/l Ag | PAN | HI93737-01 | |
硫酸盐 | 0 to 150mg/l SO4 | 浊度比色法 | HI93751-01 | |
锌 | 0.00 to 3.00mg/l Zn | 锌试剂法 | HI93731-01 | |
光学系统 | 钨灯光源,窄波段滤波器,硅光电池,波长525nm,575nm,420nm,610nm | |||
数据存储 | 200组数据,多种数据相关信息;USB数据接口 | |||
校准模式 | 手动零点校正,采用SMD微处理技术 | |||
供电方式 | 内置9V 高性能电池或AC 230V/12VDC;50 to 60Hz | |||
GLP功能 | 内置实时时钟,背景灯显示,防水操作 | |||
自动关机 | 具有10分钟无操作自动关机节电功能 | |||
适用环境 | 0 to 50℃;RH 30 to 95%(无冷凝) | |||
尺寸重量 | 235× 200×110mm;640g(主机) | |||
国际认证 | CE认证 |
北京宏昌信科技有限公司
北京宏昌信科技有限公司
甲醛检测仪 大量现货
北京宏昌信科技有限公司
