方案下载应用领域 | 钢铁/金属 |
检测样本 | 铁 |
检测项目 | 理化分析 |
参考标准 | - |
Quantitative analysis of a bulk sample requires that the composition of the sample is homogeneous over the analyzed volume. For inhomogenous samples the calculation of the matrix effects is not correct and this can lead to wrong results in the element concentrations. For samples containing a layer structure a different quantitative evaluation has to be applied. This can be provided with the standard-based analysis in ESPRIT in combination with the STRATAGem software.
The advantage of the use of STRATAGem in combination
with Bruker ESPRIT is:
A wide range of variables can be set to fixed values or
used as fit parameters. Result graphs can be directly
checked for agreement,
The open model provides a flexible setup of the sample
structure,
Graphs of K ratios vs. HV or K ratios vs. thickness can be
generated.
This method is good for the analysis of layers with thicknesses
ranging from some nm to a few μm, depending on HV
and type of layer. It also provides accurate results for multilayer
structures.
双相不锈钢的增强纳米压痕应用
EBSD和EDS在矿物学样品的相识别和分布应用
原位压缩和拉伸变形材料的定向对比成像和EBSD分析
布鲁克扫描电镜专用原位纳米力学测试系统PI 88
布鲁克3D EDS/EBSD重构软件QUBE
布鲁克 ESPRIT 四合一分析软件
布鲁克 QUANTAX WDS波谱仪
布鲁克 QUANTAX 微区荧光光谱仪
布鲁克 平插式能谱仪FlatQUAD
布鲁克 电子背散射衍射仪 EBSD eflash FS
布鲁克 电子背散射衍射仪 EBSD
布鲁克 电子背散射衍射仪 EBSD
布鲁克 QUANTAX EDS 能谱仪(TEM)
布鲁克 , EDS, 能谱仪, SEM, TEM
TXRF全反射X射线荧光光谱仪S4 TSTAR
TXRF全反射X射线荧光光谱仪S2 PICOFOX
便携式/手持式X射线荧光光谱仪
便携式/手持式X射线荧光光谱仪
