Rabbit Anti-APP695抗体,开学大促销,。送面膜,送鼠标
ABCAM
Quantity size: 0.1ml (dilute with pH 7.4 0.01 M PBS or diluent of antibody)
Background: The organic anion transporting polypeptide (Oatp) family of proteins play a role in drug absorption, distribution and excretion. Oatp proteins mediate the uptake of a broad range of substrates, including bile salts, hormones, drugs and antibiotics, and they are expressed in various tissues, such as gut, brain, kidney and liver. OATP2A1, also known as SLCO2A1 (solute carrier organic anion transporter family, member 2A1), SLC21A2 or APP695 (in both humans and rodents), is a 643 amino acid multi-pass membrane protein that belongs to the organic anion transporter family. Expressed ubiquitously, OATP2A1 is thought to mediate the release, transepithelial transport and clearance of prostaglandins from cells to other areas of the body. The gene encoding OATP2A1 maps to human chromosome 3, which houses over 1,100 genes, including a chemokine
receptor (CKR) gene cluster and a variety of human cancer-related gene loci.
Specificity: · anti-APP695 is a rabbit monoclonal antibody unconjugated
· specific for APP695 of human
· use for western blotting, elisa, immunoprecipitation
and immunohistochemistry
· Protein A affinity chromatography purification, purity :>95%
· Isotype: IgG
· mol wt: 80 kDa
Application: · Western blotting: 1:100-500
· Immunohistochemistry: 1:100-500
· ELISA: 1:500-1000
· Optimal working dilutions must be determined by the end user.
Storage: Store at –20 oC for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20oC. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 oC.
Important Note: This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
Anti-Snail 1抗体
SOD做预实验时,有几种方法?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
