Rabbit Anti-CD4抗体, RBITC 红色标记说明书conjugated
RICKY
Catalog Number : RSF-0647R-RBITC
Quantity size : 100ug (2mg/ml,Lyophilized. Buffer = 0.01M PBS, pH 7.4 with 10mg/ml BSA and
0.1% Sodium azide. Reconstitute with 100ul sterile distilled water. )
background:
This gene encodes a membrane glycoprotein of T lymphocytes that interacts with major
histocompatibility complex class II antigenes and is also a receptor for the human
immunodeficiency virus. This gene is expressed not only in T lymphocytes, but also in B cells,
macrophages, and granulocytes. It is also expressed in specific regions of the brain. The protein
functions to initiate or augment the early phase of T-cell activation, and may function as an
important mediator of indirect neuronal damage in infectious and immune-mediated diseases of
the central nervous system. Multiple alternatively spliced transcript variants encoding different
isoforms have been identified in this gene. [provided by RefSeq, Aug 2010].
Function:
Accessory protein for MHC class-II antigen/T-cell receptor interaction. May regulate T-cell
activation. Induces the aggregation of lipid rafts.
Specificity : · anti-CD4 is a rabbit Polyclonal antibody, RBITC conjugated
· specific for anti-CD4/RBITC of mouse human and rat.
· Protein G affinity chromatography purification, purity :>95%
· Isotype: IgG
· mol wt:48kDaAnti-CD4抗体, RBITC 红色标记说明书
Application : · FCM: 1:50-200
·IF : 1:50-1:200
· Immunocytochemistry: 1:50-1:200
· Excitation spectrum: 540 nm
· Emission spectrum: 625 nm
· Optimal working dilutions must be determined by the end user.
· protect from light.
Storage: Store at –20 oC for one year. Avoid repeated freeze/thaw cycles. The lyophilized
antibody is stable at room temperature for at least one month and for greater than a year when kept
at -20oC. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody, the antibody is
stable for at least two weeks at 2-4 oC.
Important Note: This product as supplied is intended for research use only, not for use in human,
therapeutic or diagnostic applications.Anti-CD4抗体, RBITC 红色标记说明书
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
Anti-Snail 1抗体
SOD做预实验时,有几种方法?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
