Anti-Integrin Alpha V + Beta 3 (CD51+CD61)
Catalog Number : Rs-1310R
Quantity size : 0.1ml (dilute with pH 7.4 0.01 M PBS or antibody diluent )
Background:
Integrins are integral cell-surface proteins composed of an alpha chain and a beta chain. They are known to participate in cell adhesion as well as cell-surface mediated signalling. Integrins are heterodimeric integral membrane proteins composed of an alpha chain and a beta chain.CD51 encodes integrin alpha chain V. The I-domain containing integrin alpha V undergoes post-translational cleavage to yield disulfide-linked heavy and light chains, that combine with multiple integrin beta chains to form different integrins. The CD61 protein product is the integrin beta chain beta 3. Integrin beta 3 is found along with the alpha IIb chain in platelets.Integrin alpha V/beta 3 is a receptor for cytotactin, fibronectin, laminin, matrix metalloproteinase 2, osteopontin, osteomodulin, prothrombin, thrombospondin, vitronectin and von Willebrand factor. Integrin alpha V/beta 3 recognizes the sequence R-G-D in a wide array of ligands. The alpha V integrins are receptors for vitronectin, cytotactin, fibronectin, fibrinogen, laminin, matrix metalloproteinase 2, osteopontin, osteomodulin,
prothrombin, thrombospondin and von Willebrand factor. They recognize the sequence R-G-D in a wide array of
ligands.pecificity :
- Anti-Integrin Alpha V + Beta 3 is a Rabbit polyclonal antibody unconjugated
specific forIntegrin Alpha V + Beta 3 of Human, Mouse, Rat, Dog
– use for western blotting,elisa,immunoprecipitation and immunohistochemistry
– Protein G affinity chromatography purification, purity :>95%
– Isotype: IgG
– mol wt:18kDa
Application :
– WB=1:100-1000 ELISA=1:500-1000 IP=1:20-100 IHC-P=1:100-1000 IHC-F=1:100-1000 IF=1:100-500
not yet tested in other applications.
– optimal dilutions/concentrations should be determined by the end user..
Storage: Store at -20℃ for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20℃. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody, the antibody is stable for at least six weeks at 2-4 ℃
Important Note: This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
Anti-Snail 1抗体
SOD做预实验时,有几种方法?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
