方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | Application note |
Ion Conductance Microscopy(ICM)is useful for obtaining contact-free images of the surface topography and has been used for imaging cultured cells under liquid conditions.The Approach-Retract-Scan(ARS) mode is a new mode of ICM, which is especially powerful for imaging samples with steep slopes. To examine the applicability of ARS mode for imaging biological samples with greater height gaps, dense collagen fibril networks were examined by ICM.
利用原子力显微镜对二维异质结构上莫列波纹的研究
利用导电探针原子力显微镜(CP-AFM)测量碳纳米管薄膜导电性
利用AFM PINPOINT 纳米机械模式定量材料的弹性模量 比力体积谱快两个数量级
