方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | / |
Introduction Generally, a sample for CD measurement needs to be in a liquid state to allow transmission measurement, more recently there has been increasing requirement for CD measurement of samples that are insoluble or may change structure in solution. These types of sample are best measured in solid state. Although CD measurement can be made in transmission for solid samples, there is a requirement for sample preparation; such as making a pellet and if sample dilution is required, sample recovery can be difficult. As an alternative, measurement using Diffuse Reflection (DR) CD is recommended. 1), 2) This application note illustrates the use of DRCD measurement with the DRCD-575 diffuse reflectance accessory (See Fig. 1.) optimized for the J-1500 CD spectrometer with the multi-probe simultaneous CD/LD measurement. DRCD uses incident light to illuminate a solid sample and
Introduction
measurement.
超临界液相色谱法分析E-液体中尼古丁的对映体
用CD光谱法评估VHH抗体的高阶结构、稳定性和相似性
使用Clear View™ATR的红外显微镜测量洗面奶中的微粒
JASCO圆二色光谱仪CD J-1500
JASCO振动圆二色光谱仪VCD FVS-6000
JASCO圆偏振荧光光谱仪CPL-300
JASCO高效色谱仪LC-4000
jascoRFT-6000傅立叶变换红外拉曼光谱仪
JASCO红外显微镜IRT-7200
MSV-5000显微紫外可见近红外分光光度计
jasco紫外可见分光光度计 V-700
JASCO FTIR-4000傅立叶变换红外光谱仪
JASCO 全自动数字旋光仪P-2000
JASCOFP-8000系列荧光光谱仪
JASCO SFC4000超临界流体色谱仪
JASCONRS5000/7000共聚焦激光拉曼光谱仪
JASCO V-7000系列紫外可见近红外分光光度计
JASCO傅立叶变换红外光谱仪FT/IR-6000
