方案下载应用领域 | 生物产业 |
检测样本 | 生物发酵 |
检测项目 | |
参考标准 | JIST |
CD spectrum and fluorescence spectrum are used in a complementary manner in the structural analysis of the proteins. The thermodynamic parameters of the protein obtained by the measurement with variable temperature provide the important knowledge for the thermal stability of the protein. The Temperature/Wavelength Scan program for JASCO CD spectrometers allows to obtain the data of CD with the temperature change for the protein and DNA required to calculate the denaturation temperature (Tm), enthalpy change (DH), and entropy change (DS). In addition such program also enables temperature interval measurements of CD and fluorescence spectra. The obtained data can be processed on the [Spectrum Analysis] and [Interval Analysis] program, which also enables to show the 3D representation. The secondary structure analysis and the calculation of thermodynamic parameters of the protein can be implemented by using optional [Thermal Denaturation Analysis] and [Protein SSE] program. This report introduces the measurement of Lysozyme (0.03 mg/mL) using Temperature/Wavelength Scan program as an example. Key words: CD spectra measurement, Fluorescence spectra measurement, Melting temperature, Proteins
超临界液相色谱法分析E-液体中尼古丁的对映体
用CD光谱法评估VHH抗体的高阶结构、稳定性和相似性
使用Clear View™ATR的红外显微镜测量洗面奶中的微粒
JASCO圆二色光谱仪CD J-1500
JASCO振动圆二色光谱仪VCD FVS-6000
JASCO圆偏振荧光光谱仪CPL-300
JASCO高效色谱仪LC-4000
jascoRFT-6000傅立叶变换红外拉曼光谱仪
JASCO红外显微镜IRT-7200
MSV-5000显微紫外可见近红外分光光度计
jasco紫外可见分光光度计 V-700
JASCO FTIR-4000傅立叶变换红外光谱仪
JASCO 全自动数字旋光仪P-2000
JASCOFP-8000系列荧光光谱仪
JASCO SFC4000超临界流体色谱仪
JASCONRS5000/7000共聚焦激光拉曼光谱仪
JASCO V-7000系列紫外可见近红外分光光度计
JASCO傅立叶变换红外光谱仪FT/IR-6000
