方案下载应用领域 | 制药/生物制药 |
检测样本 | 化药制剂 |
检测项目 | 理化性质>旋光度 |
参考标准 | 无 |
Optical rotation of Dextromethorphan Hydrobromide in accordance with the U.S. Pharmacopeia, is requested to be measured at 325 nm, however there is no emission line of 325 nm available in the polarimeter using Na lamp or Hg lamp as light source. Therefore, for the measurement of optical rotation of Dextromethorphan Hydrobromide, a polarimeter with halogen lamp as a light source and interference filter (325 nm) has been usually used, but as shown in Fig. 1, the optical rotatory dispersion (ORD) spectrum, there is a very steep slope in the short wavelength range near 325 nm, where even a very small error in the wavelength of interference filter may cause a very large error in the optical rotation measurement, which will makes the accurate measurements very difficult. On the other hand, if the measurement by using 365nm is allowed, since no wavelength error is expected, the measurement of optical rotation can be implemented with much higher accuracy. In this experiment, Dextromethorphan Hydrobromide was measured using polarimeter with Hg lamp (365 nm), polarimeter with Halogen lamp and interference filter (325 nm) and polarimeter with ORD attachment.
使用CD分析安非他命及其对映异构体
使用圆二色自动滴定装置分析人血清白蛋白与水杨酸相互作用
使用停留圆二色光谱研究三氟乙醇对刀豆蛋白A的展开
JASCO日本分光 圆二色光谱仪/圆二色谱 J-1500
JASCO 日本分光 高端圆二色光谱仪/圆二色谱仪 J-1700
JASCO 日本分光 振动圆二色光谱仪 FVS-6000
JASCO CPL-300圆偏振荧光光谱仪
JASCO FTIR-6000傅里叶变换红外光谱仪
日本分光(JASCO)荧光光谱仪 FP-8050系列
JASCO分光光度计V770
JASCO P-2000旋光仪
JASCO V-730紫外/可见/近红外分光光度计
JASCO分光光度计V780
JASCO分光光度计V760
JASCO分光光度计V750
JASCO 紫外可见分光光度计 V730
JASCO VFT-4000振动圆二色光谱仪
圆二色光谱测样服务
