蔗糖和薄荷醇的旋光测定
2019/12/22   下载量: 1
方案下载
应用领域 食品/农产品
检测样本 食糖
检测项目 理化分析>物理性指标
参考标准
Optical rotation is the property of substances, rotating the plane of polarization when linearly-polarized light passes through such substances. This is the property which occurs specifically to optical active substances in which the refractive indices of right and left circularly-polarized light are different. Optical rotation that rotate light in a clockwise direction as viewed towards the light source is defined as dextrorotation (+) and the opposite, levorotation (-).
方案下载
配置单
方案详情
The angle of rotated plane of polarization is called as optical rotation and polarimeter is the instrument to measure such optical rotation. Optical rotation is proportional to cell pathlength and is related to sample concentration, measurement wavelength and temperature. The specific optical rotation [a]tx is calculated from the following formula using temperature t (ºC), wavelength x (nm), cell pathlength 1 (dm), sample concentration c (g/100 ml) and measured optical rotation a.
上一篇 使用CD分析安非他命及其对映异构体
下一篇 用钠灯和卤素灯测定吡柔比星的旋光
文献贡献者
JASCO 公司
金牌会员第7年
查看全部资料
相关方案
当前位置: JASCO 方案 蔗糖和薄荷醇的旋光测定
