方案下载应用领域 | 制药/生物制药 |
检测样本 | 化药制剂 |
检测项目 | 理化性质>旋光度 |
参考标准 | 无 |
An emission line of light source such as a sodium lamp or a mercury lamp is usually used to measure the optical rotation of pharmaceutical products. However, the Japanese Pharmacopeia and the European Pharmacopeia only mention the use of a sodium lamp as the light source. A polarimeter using a halogen lamp and a band pass filter (BPF) can also be used, as mentioned in the United States Pharmacopeia. However, the measurement error from the transmission property, that is the difference between the center wavelength of the BPF and the wavelength of emission line, cannot be avoided. Herein, the optical rotation of pirarubicin was measured using a sodium lamp and a halogen lamp, and the measurement error between the results was evaluated.
使用CD分析安非他命及其对映异构体
使用圆二色自动滴定装置分析人血清白蛋白与水杨酸相互作用
使用停留圆二色光谱研究三氟乙醇对刀豆蛋白A的展开
JASCO日本分光 圆二色光谱仪/圆二色谱 J-1500
JASCO 日本分光 高端圆二色光谱仪/圆二色谱仪 J-1700
JASCO 日本分光 振动圆二色光谱仪 FVS-6000
JASCO CPL-300圆偏振荧光光谱仪
JASCO FTIR-6000傅里叶变换红外光谱仪
日本分光(JASCO)荧光光谱仪 FP-8050系列
JASCO分光光度计V770
JASCO P-2000旋光仪
JASCO V-730紫外/可见/近红外分光光度计
JASCO分光光度计V780
JASCO分光光度计V760
JASCO分光光度计V750
JASCO 紫外可见分光光度计 V730
JASCO VFT-4000振动圆二色光谱仪
圆二色光谱测样服务
