期刊:Environmental and Experimental Botany(EEB)
主题:MsPIP2; 2提升转基因拟南芥耐盐性
标题:MsPIP2; 2, a novel aquaporin gene from Medicago sativa, confers salt tolerance in transgenic Arabidopsis
影响因子:3.712
检测指标: Na+、K+流速
检测部位:伸长区,距离根尖550-600μm
Na+、K+流实验处理方法:
7日龄拟南芥,150mM NaCl处理24小时
Na+、K+流实验测试液成份:
文献无
推荐测试液成份:
Na+:0.5mMNaCl ,0.3mM MES,pH6.0
K+:0.1mMKCl ,0.3mM MES,pH6.0
通讯作者:西北农林科技大学杨培志
英文摘要
Aquaporins (AQPs) are channel proteins that
facilitate water transport across cell membranes and play important
roles in many biological processes. However, most AQP functions are
still poorly understood in the plant kingdom. Here, MsPIP2;2 was
isolated and identified from alfalfa (Medicago sativa). MsPIP2;2 was
localized to the plasma membrane, and its expression was induced by salt
and abscisic acid (ABA) treatment. Overexpression of MsPIP2;2 in
Arabidopsis increased the seed germination rate, seedling root length,
survival rate, proline content and antioxidant defence activity and
decreased cell membrane damage and reactive oxygen species (ROS)
accumulation compared to those in WT under salt stress.
The salt
tolerance of MsPIP2;2 was affected by Ca2+ and pH in transgenic
Arabidopsis plants. MsPIP2;2-overexpressing plants maintained a better
K+/Na+ ratio and higher Ca2+ content under salt stress. The higher
K+/Na+ maintenance in transgenic plants was mainly achieved by
increasing Na+ efflux and K+ retention in roots via regulating the
expression of the related ion channel genes. Stress-responsive genes,
including P5CS1, RD29A, DREB2 and KIN2, were upregulated in transgenic
plants under salt stress.
These results suggest that MsPIP2;2
confers salt tolerance by regulating antioxidant defence system-mediated
ROS scavenging, K/Na ion homeostasis and stress-responsive gene
expression in plants.
中文摘要(谷歌机翻)
水通道蛋白(AQPs)是促进水跨细胞膜转运的通道蛋白,在许多生物过程中起重要作用。然而,大多数AQP功能在植物界仍然知之甚少。在此,从紫花苜蓿(Medicago
sativa)中分离并鉴定了MsPIP2; 2。MsPIP2;
2定位于质膜,其表达由盐和脱落酸(ABA)处理诱导。与盐胁迫下WT相比,拟南芥中MsPIP2;
2的过量表达提高了种子萌发率,幼苗根长,存活率,脯氨酸含量和抗氧化防御活性,降低了细胞膜损伤和活性氧(ROS)积累。
MsPIP2;
2的耐盐性受转基因拟南芥植物中Ca2+和pH的影响。MsPIP2; 2过表达植物在盐胁迫下保持更好的K+ /
Na+比率和更高的Ca2+含量。转基因植物中较高的K+ /
Na+维持率主要通过调节相关离子通道基因的表达来增加根中的Na+流出和K+保留来实现。应激反应基因,包括P5CS1,RD29A,DREB2和KIN2,在盐胁迫下在转基因植物中上调。
这些结果表明,MsPIP2; 2通过调节抗氧化防御系统介导的ROS清除,K / Na离子稳态和植物中的应激反应基因表达来赋予耐盐性。
Fig. 9. The net ?ux of Na+ and K+ at the root tip elongation zones of 7-day-old Arabidopsis seedlings. (A) The net Na+ ?ux under normal conditions (0 mM NaCl). (B) The net Na+ ?ux after 150 mM NaCl stress. (C) The mean Na+ ?ux. (D) The net K+ ?ux under normal conditions (0 mM NaCl). (E) The net K+ ?ux after 150 mM NaCl stress. (F) The mean K+ ?ux. Bars represent the mean ± SE (n = 3). Asterisks and double asterisks above the bars indicate signi?cant di?erences between the transgenic lines and the WT under the same growth conditions: *, P < 0.05; **, P < 0.01.
文章链接:
https://www.sciencedirect.com/science/article/abs/pii/S0098847219300036
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
