期刊:BMC Plant Biology
主题:BjHMA4R通过结合胞质Cd2+促植物耐镉
标题:A repeat region from the Brassica juncea HMA4 gene BjHMA4R is specifically involved in Cd2+ binding in the cytosol under low heavy metal concentrations
影响因子:3.930
检测指标: Cd2+流速
检测部位:大肠杆菌细胞,酵母细胞
Cd2+流实验处理方法:
大肠杆菌,酵母细胞,30μMCdCl2胁迫
Cd2+流实验测试液成份:
文献无
推荐测试液成份:
0.03 mM CdCl2, 0.3 mM MES, 10 mM glucose, pH 6.0
通讯作者:中国科学院大学生命科学学院柴团耀、梁爽
HMA4 transporters are involved in the transport and
binding of divalent heavy metals (Cd, Zn, Pb [lead] and Co [cobalt]). In
general, as efflux pumps, HMA4 transporters can increase the heavy
metal tolerance of yeast and Escherichia coli. Additional research has
shown that the C-terminus of HMA4 contains a heavy metal-binding domain
and that heterologous expression of a portion of peptides from this
C-terminal domain in yeast provides a high level of Cd tolerance and Cd
hyperaccumulation.
We cloned BjHMA4 from Brassica juncea, and
quantitative real-time PCR analysis revealed that BjHMA4 was upregulated
by Zn and Cd in the roots, stems and leaves. Overexpression of BjHMA4
dramatically affects Zn/Cd distribution in rice and wheat seedlings.
Interestingly, BjHMA4 contains a repeat region named BjHMA4R within the
C-terminal region; this repeat region is not far from the last
transmembrane domain. We further characterized the detailed function of
BjHMA4R via yeast and E. coli experiments. Notably, BjHMA4R greatly and
specifically improved Cd tolerance, and BjHMA4R transformants both grew
on solid media that contained 500?μM CdCl2 and presented improved Cd
accumulation (approximately twice that of wild-type [WT] strains).
Additionally, visualization via fluorescence microscopy indicated that
BjHMA4R clearly localizes in the cytosol of yeast. Overall, these
findings suggest that BjHMA4R specifically improves Cd tolerance and Cd
accumulation in yeast by specifically binding Cd2+ in the cytosol under
low heavy metal concentrations. Moreover, similar results in E. coli
experiments corroborate this postulation.
BjHMA4R can
specifically bind Cd2+ in the cytosol, thereby substantially and
specifically improving Cd tolerance and accumulation under low heavy
HMA4转运蛋白参与二价重金属(Cd,Zn,Pb [铅]和Co
[钴])的转运和结合。通常,作为外排泵,HMA4转运蛋白可以增加酵母和大肠杆菌的重金属耐受性。另外的研究表明,HMA4的C末端含有重金属结合结构域,并且酵母中来自该C末端结构域的一部分肽的异源表达提供了高水平的Cd耐受性和Cd超积累。
我们从芥菜中克隆了BjHMA4,定量实时PCR分析表明BjHMA4在根,茎和叶中被Zn和Cd上调。BjHMA4的过表达显着影响水稻和小麦幼苗的Zn
Cd分布。有趣的是,BjHMA4在C末端区域内含有一个名为BjHMA4R的重复区域;这个重复区域距离最。后一个跨膜结构域不远。我们通过酵母和大肠杆菌实验进一步表征了BjHMA4R的详细功能。值得注意的是,BjHMA4R极大地且特异性地改善了Cd耐受性,并且BjHMA4R转化体均在含有500μMCdCl2的固体培养基上生长并且呈现出改善的Cd积累(大约是野生型[WT]菌株的两倍)。另外,通过荧光显微镜观察表明BjHMA4R清楚地定位于酵母的胞质溶胶中。总体而言,这些发现表明BjHMA4R通过在低重金属浓度下特异性结合胞质溶胶中的Cd2+,特异性地改善了酵母中的Cd耐受性和Cd积累。此外,大肠杆菌实验中的类似结果证实了这种假设。
BjHMA4R可特异性结合胞质溶胶中的Cd2+,从而在低重金属浓度下基本上和特异性地改善Cd耐受性和积累。
Fig. 12. Detection of BjHMA4R activity by Cd2+ flux measurements. Transgenic BjHMA4R and control cells were exposed to 30?μM Cd2+ and measurements were taken for 600?s, using a vibrating probe, after the flux became ready. a yeast cells, b E. coli cells. The data are expressed as the mean?±?SE of three replicates; * and ** indicate significant levels at 5 and 1% (evaluated by Student’s t test), respectively
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
