NMT历史上的今天
2018年8月6日,北京林业大学尹伟伦、孟森利用NMT技术在International journal of molecular sciences 上发表了标题为Distinct Carbon and Nitrogen Metabolism of Two Contrasting Poplar Species in Response to Different N Supply Levels的文章。影响因子为3.687。
2012年8月6日,中科院海洋所王广策、林阿朋利用NMT技术在Physiologia Plantarum上发表了标题为Simultaneous measurements of H+and O2 fluxes in Zostera marina and its physiological implications 的文章。影响因子为3.067.
期刊:International journal of molecular sciences
主题:两种杨树对不同氮素供应水平的碳氮代谢差异
标题:Distinct Carbon and Nitrogen Metabolism of Two Contrasting Poplar Species in Response to Different N Supply Levels
影响因子:3.687
检测指标:NH4+、NO3-、H+流速流速
检测部位:杨树根部
NH4+、NO3-、H+流实验处理方法:
杨树在低中高(0.01,1或10 mM的NH4NO3)的氮浓度下处理4周
NH4+、NO3-、H+流实验测试液成份:
0.01mM/1mM/10mM NH4NO3,0.1mM KCl,0.1mM CaCl 2,pH 5.5
通讯作者:北京林业大学尹伟伦、孟森
英文摘要
Poplars have evolved various strategies to optimize
acclimation responses to environmental conditions. However, how poplars
balance growth and nitrogen deficiency remains to be elucidated.
In
the present study, changes in root development, carbon and nitrogen
physiology, and the transcript abundance of associated genes were
investigated in slow-growing Populus simonii (Ps) and fast-growing
Populus euramericana (Pe) saplings treated with low, medium, and high
nitrogen supply. The slow-growing Ps showed a flourishing system, higher
δ15N, accelerated C export, lower N uptake and assimilation, and less
sensitive transcriptional regulation in response to low N supply.
The
slow-growing Ps also had greater resistance to N deficiency due to the
transport of photosynthate to the roots and the stimulation of root
development, which allows survival. To support its rapid metabolism and
growth, compared with the slow-growing Ps, the fast-growing Pe showed
greater root development, C/N uptake and assimilation capacity, and more
responsive transcriptional regulation with greater N supply. These data
suggest that poplars can differentially manage C/N metabolism and
photosynthate allocation under different N supply conditions.
中文摘要(谷歌机翻)
杨树已经发展出各种策略来优化对环境条件的适应性反应。然而,杨树如何平衡生长和氮缺乏仍有待阐明。
在本研究中,在慢生长的小叶杨(Pops
simonii)(Ps)和快速生长的欧洲杨(Populus
euramericana(Pe)幼树)中研究了根系发育,碳和氮生理学以及相关基因的转录本丰度的变化。高氮供应。缓慢生长的Ps显示出繁殖系统,更高的δ15N,加速的C输出,更低的N吸收和同化,以及响应于低N供应的较不敏感的转录调节。
由于光合产物向根部的转运和根系发育的刺激,缓慢生长的Ps对N缺乏具有更大的抗性,这允许存活。为了支持其快速代谢和生长,与生长缓慢的Ps相比,快速生长的Pe显示出更大的根发育,C
/ N吸收和同化能力,以及具有更大N供应的更具响应性的转录调节。这些数据表明,杨树可以在不同的氮供应条件下差异化地控制C /
N代谢和光合产物分配。
Figure 4. Net NH4+ (A), NO3? (B) and H+ (C) fluxes
of P. simonii (Ps) and Populus euramericana (Pe) under 0.01, 1 and 10 mM
NH4NO3. Bars labelled with different letters indicate significant
difference between the treatments. p-Values of the ANOVAs of species, N
treatment, and their interaction are indicated. ** p < 0.01; *** p
< 0.001; ns, not significant.
期刊:Physiologia Plantarum
主题:同时测量H+和O2流速及其生理意义
标题:Simultaneous measurements of H+ and O2 fluxes in Zostera marina and its physiological implications
影响因子:3.067
检测指标:H+、O2流速
检测部位:大叶藻叶片
H+、O2流实验处理方法:
大叶藻叶片瞬时由暗至光(300μmolm-2s-1)处理
H+、O2流实验测试液成份:
天然海水(NSW)盐浓度30–32‰
通讯作者:中科院海洋所王广策、林阿朋
英文摘要
Zostera marina (eelgrass) is an important ecological
component of many shallow, temperate lagoons. Evidence suggests that Z.
marina has a high bicarbonate utilization capability, which could be
promoted by possible proton extrusion and the consequent formation of an
‘acid zone’ in the apoplastic space (unstirred layer) of its leaves.
It
has been found that 50?mM of the buffer Tris significantly inhibited
the photosynthetic O2 evolution of Z. marina and it was proposed that
this was because of Tris's ability to bond with protons outside the cell
wall. To investigate if H+ played an important role in the
photosynthetic carbon utilization of Z. marina, it is very important to
simultaneously monitor the photosynthesis status and possible H+ fluxes.
However, probably because of the lack of suitable techniques, this has
never been attempted.
In this study, experiments were undertaken
on Z. marina by monitoring H+ and O2 fluxes and the relative electron
transport rates during light–dark transition. During stable
photosynthesis, in addition to an obvious O2 outflow, there was a
significant net H+ influx connected to Z. marina photosynthesis. The
inhibitory effects of both Tris and respiration inhibitors on apparent
O2 evolution of Z. marina were confirmed. However, evidence did not
support the proposed Tris inhibition mechanism.
中文摘要(谷歌机翻)
Zostera marina(eelgrass)是许多浅水温带泻湖的重要生态组成部分。有证据表明,Z。marina具有较高的碳酸氢盐利用能力,可以通过可能的质子挤出促进,并因此在其叶片的非质外体空间(未搅拌层)中形成“酸性区域”。
已经发现50mM的缓冲液Tris显着抑制了Z.marina的光合作用O2进化,并且提出这是因为Tris能够与细胞壁外的质子结合。为了研究H
+是否在Z. marina的光合碳利用中起重要作用,同时监测光合作用状态和可能的H
+通量是非常重要的。然而,可能由于缺乏合适的技术,这从未尝试过。
在这项研究中,通过监测H
+和O2通量以及在明暗过渡期间的相对电子传输速率对Z.marina进行了实验。在稳定的光合作用期间,除了明显的O2流出外,还有显着的净H
+流入与Z. marina光合作用相关。证实了Tris和呼吸抑制剂对Z.
marina的表观O2进化的抑制作用。然而,证据不支持所提出的Tris抑制机制。
Fig. 1. Typical transient changes in H+ ?ux near Zostera
marina leaf segments in response to bright white light. The result of a
single measurement is used in this ?gure as multiple results in one
graph would result in large ?uctuations and mask the transient
responses. The sample was dark adapted for >1 h. After 25 min of
measurement, leaf segments were exposed to bright white light (300 μmol
m?2 s?1)for 15 min. Measurements were made at intervals of 6.4 s. Each
point on the graph represents average data over an interval of three
measurements.
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
