稍后还会为大家带来一作视频讲解
期刊:Food Chemistry
主题:钙参与盐胁迫下作物酚类积累的GABA信号转导(钙信号)
标题:Ca2+ involved in GABA signal transduction for phenolics accumulation in germinated hulless barley under NaCl stress
影响因子:5.399
检测指标:Ca2+流速
检测部位:根尖细胞
Ca2+流实验处理方法:
三日龄的大麦幼苗,60mM NaCl、60mM NaCl + 0.5mM GABA、60mM NaCl + 0.1mM 3-MP分别处理四天和六天
Ca2+流实验测试液成份:
0.1mM KCl, 0.1mM CaCl2, 0.1mM MgCl2, 0.5mM NaCl, 0.3mM MES, 0.2mM Na2SO4,ph 6.0
通讯作者:南京农业大学杨润强、马燕
英文摘要
In this study, in order to investigate the role of
Ca2+ in GABA signal transduction involved in phenolics accumulation in
barley seedlings under NaCl stress, the seedlings were treated with
exogenous GABA and its synthesis inhibitor, 3-mercaplopropionic acid
(3-MP), as well as Ca2+ channel blockers La3+, Ca2+ chelator EGTA, and
Ca2+ release channel inhibitor 2-aminoethoxydiphenyl borate (2-APB).
The
results showed that GABA significantly enhanced phenolics, calcium and
calmodulin content. It also induced Ca2+ influx in barley root tips
cells, and altered the distribution of Ca2+, making calcium precipitates
more uniform and intensive. While, 3-MP treatment led to opposite
changes, which suggested that GABA was essential for calcium content
increase. In addition, accumulation of phenolics was inhibited by LaCl3,
EGTA and 2-APB treatments, and this inhibition could be alleviated
partly by exogenous GABA.
Taken together, Ca2+ was involved in GABA signal transduction for phenolics accumulation in barley seedlings under NaCl stress.
中文摘要(谷歌机翻)
在本研究中,为了研究Ca2+在NaCl胁迫下大麦幼苗中酚类物质积累的GABA信号转导中的作用,用外源GABA及其合成抑制剂3-巯基丙酸(3-MP)处理幼苗。以及Ca2+通道阻滞剂La3+,Ca2+螯合剂EGTA和Ca2+释放通道抑制剂2-氨基乙氧基二苯基硼酸盐(2-APB)。
结果表明,GABA显着增强了酚类,钙和钙调蛋白的含量。它还诱导大麦根尖细胞内的Ca2+流入,并改变Ca2+的分布,使钙沉淀更均匀和密集。然而,3-MP处理导致相反的变化,这表明GABA对钙含量的增加至关重要。此外,LaCl3,EGTA和2-APB处理抑制了酚类物质的积累,这种抑制作用可以通过外源性GABA部分缓解。
总之,Ca2+参与了NaCl胁迫下大麦幼苗中酚类物质积累的GABA信号转导。
结果表明,对照大麦幼苗根尖Ca2+外排,与对照相比,NaCl处理引起的Ca2+由外排向吸收转变。GABA处理得到稳定的Ca2+吸收,其中处理6天的吸收明显高于处理4天吸收。GAD抑制剂(3-MP)在不同处理时期产生了不同的趋势,与单独使用NaCl处理相比,第4天Ca2+的外排速率显着增加,但第6天Ca2+流入量较弱。
注:CK表示大麦用蒸馏水喷洒; N表示60mM NaCl处理; NG表示60mM NaCl + 0.5mM GABA处理; NM表示60mM NaCl + 0.1mM 3-MP处理。
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
