期刊:cell research
主题:钙离子启动免疫系统的分子机制
标题:A cyclic nucleotide-gated channel mediates cytoplasmic calcium elevation and disease resistance in rice
影响因子:17.848
检测指标:Ca2+流速
检测部位:水稻叶肉细胞
Ca2+流速流实验处理方法:
水稻幼苗,10uM chitin或10uM flg22肽瞬时胁迫
Ca2+流速流实验测试液成份:
0.2mM CaCl2, 0.1mM NaCl, 0.1mM MgCl2 and 0.1mM KCl,pH 5.2
作者:中国农科院万建民、王家昌
英文摘要
The transient elevation of cytoplasmic calcium is
essential for pathogen-associated molecular pattern (PAMP)-triggered
immunity (PTI). However, the calcium channels responsible for this
process have remained unknown.
Here, we show that rice CDS1 (CELL DEATH and SUSCEPTIBLE to BLAST 1)
encoding OsCNGC9, a cyclic nucleotide-gated channel protein, positively
regulates the resistance to rice blast disease. We show that OsCNGC9
mediates PAMP-induced Ca2+ influx and that this event is critical for
PAMPs-triggered ROS burst and induction of PTI-related defense gene
expression. We further show that a PTI-related receptor-like
cytoplasmic kinase OsRLCK185 physically interacts with and
phosphorylates OsCNGC9 to activate its channel activity.
Our results suggest a signaling cascade linking pattern recognition to
calcium channel activation, which is required for initiation of PTI and
disease resistance in rice.
中文摘要(谷歌机翻)
细胞质钙的瞬时升高对病原体相关分子模式(PAMP)- 触发免疫(PTI)至关重要。然而,负责该过程的钙通道仍然未知。
在这里,我们显示编码OsCNGC9(环核苷酸门控通道蛋白)的水稻CDS1(CELL DEATH和SUSCEPTIBLE to BLAST
1)正向调节对稻瘟病的抗性。我们显示OsCNGC9介导PAMP诱导的Ca2+内流,并且该事件对于PAMPs触发的ROS爆发和诱导PTI相关的防御基因表达是至关重要的。我们进一步显示PTI相关受体样细胞质激酶OsRLCK185与OsCNGC9物理相互作用并使其磷酸化以激活其通道活性。
我们的研究结果表明信号级联将模式识别与钙通道激活联系起来,这是启动水稻PTI和抗病性所必需的。
结果表明:响应于几丁质或flg22刺激,WT叶肉细胞比cds1叶肉细胞表现出强烈且快速的Ca2+流入(图3a,b和补充信息,图S6)。这些结果表明OsCNGC9可以介导水稻PTI中的Ca2+流入,并且这种能力在cds1突变体中受损。
结果表明:响应几丁质刺激,Nipponbare叶肉细胞比Osrlck185/
55双突变体叶肉细胞,表现出快速的Ca2+内流(图e)。此外,在几丁质处理Oscerk1敲除突变体后未观察到显着的Ca2+流入(图f)。这些结果共同表明OsRLCK185及其紧密同源物OsRLCK55参与水稻抗稻瘟病和PAMP诱导的Ca2+内流的调节。
结果表明:在PAMPs刺激后,与Kitaake植物相比,OsCNGC9-OE转基因植物的叶肉细胞显示出更强的Ca2+流入。结合其他实验表明,OsCNGC9是水稻PTI的限速正调控因子。
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
