期刊:Plant Physiology
主题:NRT1.1磷酸化调节侧根发育的机制
标题:Phosphorylation-mediated dynamics of nitrate transceptor NRT1.1 regulate auxin flux and nitrate signaling in lateral root growth
影响因子:6.305
检测指标:IAA流速
检测部位:酵母细胞
IAA流速流实验处理方法:
转化酵母细胞在SD-URA培养基长到对数期,转至SG-URA培养基[SD-URA培养基中的dextrose替换为2%(m/v)galactose]上,培养24-48小时,诱导NRT1.1,T101A,T101D,mRuby表达。离心收集并制成SG-URA悬液。
IAA流速流实验测试液成份:
0.5 μM IAA, 2% (m/v) galactose, 0.3 mM MES, pH 5.8
作者:北京林业大学单晓昳、林金星、张曦
英文摘要
The dual-affinity nitrate transceptor NITRATE
TRANSPORTER 1.1 (NRT1.1) has two modes of transport and signaling,
governed by threonine101 (T101) phosphorylation. NRT1.1 regulates
lateral root (LR) development by modulating nitrate-dependent basipetal
auxin export and nitrate-mediated signal transduction.
Here,
using the Arabidopsis thaliana NRT1.1T101D phosphomimetic and
NRT1.1T101A non-phosphorylatable mutants, we found that the
phosphorylation state of NRT1.1 plays a key role in NRT1.1 function
during LR development. Single-particle tracking revealed that
phosphorylation affected NRT1.1 spatiotemporal dynamics. The
phosphomimetic NRT1.1T101D form showed fast lateral mobility and
membrane partitioning that facilitated auxin flux under low-nitrate
conditions.
By contrast, non-phosphorylatable NRT1.1T101A showed
low lateral mobility and oligomerized at the plasma membrane (PM), where
it induced endocytosis via the clathrin-mediated endocytosis and
microdomain-mediated endocytosis pathways under high-nitrate conditions.
These
behaviors promoted LR development by suppressing NRT1.1-controlled
auxin transport on the PM and stimulating Ca2+-ARABIDOPSIS NITRATE
REGULATED 1 (ANR1) signaling from the endosome.
中文摘要(谷歌机翻)
双亲和硝酸盐转运蛋白NITRATE TRANSPORTER 1.1(NRT1.1)具有两种运输和信号传导模式,由苏氨酸101(T101)磷酸化控制。 NRT1.1通过调节硝酸盐依赖性碱基生长素输出和硝酸盐介导的信号转导来调节侧根(LR)发育。
在这里,使用拟南芥NRT1.1T101D磷酸化和NRT1.1T101A非磷酸化突变体,我们发现NRT1.1的磷酸化状态在LR发育期间在NRT1.1功能中起关键作用。单粒子追踪显示磷酸化影响NRT1.1时空动态。磷酸化模拟NRT1.1T101D形式显示出快速的侧向移动性和膜分配,其促进了在低硝酸盐条件下的生长素通量。
相比之下,不可磷酸化的NRT1.1T101A显示出低的侧向迁移率并且在质膜(PM)处寡聚化,其在高硝酸盐条件下通过网格蛋白介导的内吞作用和微区介导的胞吞作用途径诱导内吞作用。
这些行为通过抑制PM上的NRT1.1控制的生长素转运并刺激来自内体的Ca2 + -ARABIDOPSIS硝酸盐调节1(ANR1)信号传导来促进LR发展。
酵母细胞IAA流检测
对照、NRT1.1、T101A、T101D转化酵母菌的IAA流(外排)结果。
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
