期刊:Plant Physiology
主题:线粒体丙酮酸载体调控植物耐镉的机理
标题:Mitochondrial Pyruvate Carriers Prevent Cadmium Toxicity by Sustaining the TCA Cycle and Glutathione Synthesis
影响因子:5.949
监测指标:Cd2+流速
检测部位:拟南芥根(距离根尖400μm)
Cd2+流速流实验处理方法:
拟南芥种子萌发3天后,50μMCdCl2处理7天
Cd2+流速流实验测试液成份:
0.1 mM KCl, 0.05 mM CdCl2, 0.3 mM MES, pH 5.8
作者:山东大学、山东省农科院张伟、高建伟、贺立龙
英文摘要
Cadmium (Cd) is a major heavy metal pollutant, and Cd
toxicity is a serious cause of abiotic stress in the environment.
Plants protect themselves against Cd stress through a variety of
pathways.
In a recent study, we found that mitochondrial pyruvate carriers (MPCs)
are involved in Cd tolerance in Arabidopsis (Arabidopsis thaliana).
Following the identification of MPCs in yeast (Saccharomyces
cerevisiae) in 2012, most studies have focused on the function of MPCs
in animals, as a possible approach to reduce the risk of cancer
developing.
The results of this study show that AtMPC protein complexes are
required for Cd tolerance and prevention of Cd accumulation in
Arabidopsis. AtMPC complexes are composed of two elements, AtMPC1 and
AtMPC2 (AtNRGA1 or AtMPC3). When the formation of AtMPCs was
interrupted by the loss of AtMPC1, glutamate could supplement the
synthesis of acetyl-coenzyme A and sustain the TCA cycle. With the
up-regulation of glutathione synthesis following exposure to Cd stress,
the supplementary pathway could not efficiently drive the tricarboxylic
acid cycle without AtMPC. The ATP content decreased concomitantly with
the deletion of tricarboxylic acid activity, which led to Cd
accumulation in Arabidopsis.
More importantly, ScMPCs were also required for Cd tolerance in yeast.
Our results suggest that the mechanism of Cd tolerance may be similar
in other species.
中文摘要(谷歌机翻)
镉(Cd)是一种主要的重金属污染物,Cd毒性是环境中非生物胁迫的严重原因。植物通过各种途径保护自己免受Cd胁迫。
在最近的一项研究中,我们发现线粒体丙酮酸载体(MPCs)参与拟南芥(Arabidopsis thaliana)的Cd耐受。继2012年在酵母(酿酒酵母)中鉴定MPC后,大多数研究都集中在MPCs在动物体内的功能,作为降低癌症发展风险的可能方法。
该研究的结果表明,AtMPC蛋白复合物是拟南芥中Cd耐受和预防Cd积累所必需的。AtMPC复合物由两种元素组成,AtMPC1和AtMPC2(AtNRGA1或AtMPC3)。当AtMPC的形成中断AtMPC的形成时,谷氨酸可以补充乙酰辅酶A的合成并维持TCA循环。随着暴露于Cd胁迫后谷胱甘肽合成的上调,补充途径不能在没有AtMPC的情况下有效地驱动三羧酸循环。随着三羧酸活性的缺失,ATP含量同时下降,导致拟南芥中Cd的积累。
更重要的是,ScMPCs也是酵母中Cd耐受性所必需的。我们的研究结果表明,其他物种的镉耐受机制可能相似。
结果表明:结果表明:在50μMCdCl2处理下,mpc1-1根系中的Cd2+吸收远高于野生型和互补株系(图C和D))。
结果表明:通过在野生型和mpc1-1的根中添加1mM
ATP,Cd2+吸收受到显着影响并变为外排。此外,野生型的Cd2+流速变化比mpc1-1更明显。野生型Cd2+流速从大约-10pmolcm-2s-1变为70pmol
cm-2s-1,而mpc1-1从大约-20pmolcm-2s-1变为20pmol
cm-2s-1(图b和c)。在MPC存在下,ATP有助于Cd2+的外排。
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
