NMT历史上的今天
2018年9月19日,北京林业大学陈少良、林善枝、赵楠、孙健利用NMT在Frontiers in Plant Science上发表了标题为Hydrogen
Sulfide Mediates K+ and Na+ Homeostasis in the Roots of Salt-Resistant
and Salt-Sensitive Poplar Species Subjected to NaCl Stress的研究成果。
期刊:Frontiers in Plant Science
主题:硫化氢介导盐胁迫和盐敏感杨树种根系中的K+和Na+稳态
标题:Hydrogen Sulfide Mediates K+ and Na+ Homeostasis in the Roots of Salt-Resistant and Salt-Sensitive Poplar Species Subjected to NaCl Stress.
影响因子:3.678
检测指标:K+、Na+、H+流速
检测部位:杨树根部(距离根尖300um)
K+、Na+、H+流实验处理方法:
一年生的胡杨幼苗,在对照,对照加NaHS(50mM),NaCl(50mM)和NaCl(50mM)加上NaHS(50mM)这四种处理分别处理24小时和5天
K+、Na+、H+流实验测试液成份:
0.1 mM KCl, 0.1 mM CaCl2, 0.1 mM MgCl2, 0.5 mM NaCl, 0.2 mM Na2SO4, and 0.3 mM MES, pH 4.0
作者:北京林业大学陈少良、林善枝、赵楠、孙健
英文摘要
Non-invasive
micro-test techniques (NMT) were used to analyze NaCl-altered flux
profiles of K+, Na+, and H+ in roots and effects of NaHS (a H2S donor)
on root ion fluxes in two contrasting poplar species, Populus euphratica
(salt-resistant) and Populus popularis (salt-sensitive).
Both
poplar species displayed a net K+ efflux after exposure to salt shock
(100 mM NaCl), as well as after short-term (24 h), and long-term (LT) (5
days) saline treatment (50 mM NaCl, referred to as salt stress). NaHS
(50 μM) restricted NaCl-induced K+ efflux in roots irrespective of the
duration of salt exposure, but K+ efflux was not pronounced in data
collected from the LT salt stress treatment of P. euphratica.
The
NaCl-induced K+ efflux was inhibited by a K+ channel blocker,
tetraethylammonium chloride (TEA) in P. popularis root samples, but K+
loss increased with a specific inhibitor of plasma membrane (PM)
H+-ATPase, sodium orthovanadate, in both poplar species under LT salt
stress and NaHS treatment. This indicates that NaCl-induced K+ loss was
through depolarization-activated K+ channels. NaHS caused increased Na+
efflux and a corresponding increase in H+ influx for poplar roots
subjected to both the short- and LT salt stress.
The
NaHS-enhanced H+ influx was not significant in P. euphratica samples
subjected to short term salt stress. Both sodium orthovanadate and
amiloride (a Na+/H+ antiporter inhibitor) effectively inhibited the
NaHS-augmented Na+ efflux, indicating that the H2S-enhanced Na+ efflux
was due to active Na+ exclusion across the PM. We therefore conclude
that the beneficial effects of H2S probably arise from upward regulation
of the Na+/H+ antiport system (H+ pumps and Na+/H+ antiporters), which
promote exchange of Na+ with H+ across the PM and simultaneously
restricted the channel-mediated K+ loss that activated by membrane
depolarization.
中文摘要
非侵入性微测试技术(NMT)用于分析NaCl中改变的根中K+,Na+和H+的通量分布以及NaHS(H2S供体)对两种对比杨树胡杨(Populus euphratica)根系离子通量的影响(耐盐)和Populus popularis(盐敏感)。
在暴露于盐休克(100mM NaCl)之后,以及在短期(24小时)和长期(LT)(5天)盐水处理(50mM NaCl,参考)之后,两种杨树物种都表现出净K+外排。作为盐胁迫)。无论盐暴露的持续时间如何,NaHS(50μM)都限制了NaCl诱导的根中的K+流出,但是从胡杨的LT盐胁迫处理收集的数据中K+流出不明显。
NaCl诱导的K+流出受到K+通道阻滞剂,四乙基氯化铵(TEA)在P.pularis根样品中的抑制,但K+损失随着特异性质膜抑制剂(PM)H+ -ATPase,原钒酸钠在杨树中的增加而增加。 LT盐胁迫和NaHS处理下的物种。这表明NaCl诱导的K+损失是通过去极化激活的K+通道。 NaHS导致Na+流出增加,并且受到短盐和LT盐胁迫的杨树根的H+流入相应增加。
经受短期盐胁迫的胡杨(P. euphratica)样品中NaHS增强的H+流入量不显着。原钒酸钠和阿米洛利(Na+ / H+逆向转运蛋白抑制剂)均有效抑制NaHS增强的Na+流出,表明H2S增强的Na+流出是由于PM中的活性Na+排斥。因此,我们得出结论,H2S的有益作用可能源于Na+ / H+反向运输系统(H+泵和Na+ / H+反向运输)的向上调节,其促进Na+与H+在PM上的交换并同时限制通道介导的K+损失。通过膜去极化激活。
FIGURE 1丨Effects of NaHS on NaCl shock-altered transient K+
kinetics within P. euphratica and P. popularis root samples. Young root
samples of P. euphratica and P. popularis were equilibrated for 30 min
in a basic solution [NaCl (0.1 mM), MgCl2 (0.1 mM), CaCl2 (0.1 mM), and
KCl (0.5 mM)] supplemented with or without 25, 50, and 200 μM NaHS.
Thereafter, K+
kinetics were recorded at meristems (300 μm from the root tip) for ca.
40 min after NaCl shock. The salt shock (100 mM NaCl) was given by
adding acquired amount of NaCl stock (0.2 M, pH 6.0 adjusted with NaOH
and HCl) to the measuring solution. Before the NaCl shock, steady-state K+
fluxes were recorded for 10 min. Each point is the mean of five
individual plants and bars represent the standard error of the mean.
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
