NMT是基因功能的活体检测技术,已被103位诺贝尔奖得主所在单位,及北大、清华、中科院使用。
NMT历史上的今天
2015年12月27日,中科院遗传发育所童依平、何雪用NMT在Plant Physiology上发表了标题为The Nitrate-Inducible NAC Transcription Factor TaNAC2-5A Controls Nitrate Response and Increases Wheat Yield的研究成果。
期刊:Plant Physiology
主题:TaNAC2-5A控制**盐反应提高小麦产量
标题:The Nitrate-Inducible NAC Transcription Factor TaNAC2-5A Controls Nitrate Response and Increases Wheat Yield
影响因子:7.394
检测指标:NO3-流速
作者:中科院遗传发育所童依平、何雪
英文摘要
Nitrate is a major nitrogen resource for cereal
crops; thus, understanding nitrate signaling in cereal crops is valuable
for engineering crops with improved nitrogen use efficiency. Although
several regulators have been identified in nitrate sensing and
signaling in Arabidopsis (Arabidopsis thaliana), the equivalent
information in cereals is missing.
Here, we isolated a nitrate-inducible and cereal-specific NAM, ATAF,
and CUC (NAC) transcription factor, TaNAC2-5A, from wheat (Triticum
aestivum). A chromatin immunoprecipitation assay showed that TaNAC2-5A
could directly bind to the promoter regions of the genes encoding
nitrate transporter and glutamine synthetase. Overexpression of
TaNAC2-5A in wheat enhanced root growth and nitrate influx rate and,
hence, increased the root’s ability to acquire nitrogen. Furthermore,
we found that TaNAC2-5A-overexpressing transgenic wheat lines had
higher grain yield and higher nitrogen accumulation in aerial parts and
allocated more nitrogen in grains in a field experiment.
These results suggest that TaNAC2-5A is involved in nitrate signaling
and show that it is an exciting gene resource for breeding crops with
more efficient use of fertilizer.
中文摘要(谷歌机翻)
**盐是谷物作物的主要氮资源。因此,了解谷类作物中的**盐信号对于提高氮素利用效率的工程作物非常有价值。尽管已经在拟南芥(Arabidopsis thaliana)的**盐感测和信号传导中确定了几种调节剂,但谷物中的等效信息却缺失了。
在这里,我们从小麦(Triticum
aestivum)中分离出了**盐诱导型和谷类特异性NAM,ATAF和CUC(NAC)转录因子TaNAC2-5A。染色质免疫沉淀分析表明,TaNAC2-5A可以直接结合到编码**盐转运蛋白和谷氨酰胺合成酶的基因的启动子区域。TaNAC2-5A在小麦中的过表达增强了根系的生长和**盐的流入速率,因此增加了根系获得氮的能力。此外,我们发现在田间试验中,过表达TaNAC2-5A的转基因小麦品系具有较高的籽粒产量和较高的氮素在地上部分的积累,并在籽粒中分配了更多的氮。
这些结果表明,TaNAC2-5A参与**盐信号传导,并表明它是利用更有效地使用肥料来育种作物的令人兴奋的基因资源。
D and E, Nitrate in?ux rates at the root tip surface
(D) and expression levels of nitrate transporters in whole seedlings
(E). Seedlings were grown for 4 d on solid medium that contained 6 mM
nitrate. The roots were used to measure nitrate ?ux rate in the
measuring solution that contained 1 mM nitrate. Data are means 6 SE for
six plants. Whole seedlings were used to analyze the expression of
nitrate trans-porters. The relative expression levels were normalized to
the expression of AtACTIN2 (AtACT2). Data are means 6 SE of three
replicates. Asterisks indicate that the difference between the means of
the wild type and the transgenic lines was signi?cant at the P , 0.05
(*) and P , 0.01 (**) levels.
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
