NMT是基因功能的活体检测技术,已被103位诺贝尔奖得主所在单位,及北大、清华、中科院使用。
期刊:Aquatic Toxicology
主题:AgNPs和CuNPs抑制斑马鱼胚胎侧线毛细胞钙吸收
标题:Toxic e?ects of silver and copper nanoparticles on lateral-line hair cells of zebra?sh embryos
影响因子:3.794
检测指标:Ca2+流速
检测样品:斑马鱼胚胎侧线毛细胞发束
Ca2+流实验处理方法:
斑马鱼胚胎经0-96hpf受精后,分别用0,0.1,1,3ppm的AgNPs和0,0.01,0.1,1ppm的CuNPs进行受精
Ca2+流实验测试液成份:
0.5mM NaCl,0.2mM CaSO4,0.2mM MgSO4,0.16mM KH2PO4,and0.16mM K2HPO4(pH 7.0),300μM MOPS,0.1mg/l tricaine
作者:台湾师范大学林豊益
英文摘要
The potential toxicity of nanoparticles (NPs) to the
early stages of fish is still unclear. In this study, we investigated
the toxic effects of silver (AgNPs) and copper nanoparticles (CuNPs) on
lateral-line hair cells of zebrafish embryos.
Zebrafish embryos were incubated in different concentrations of AgNPs
and CuNPs at 0?96 h post-fertilization (hpf). Both AgNPs and CuNPs
were found to cause toxic effects in zebrafish embryos in a
dosedependent manner. Values of the 96-h 50% lethal concentration
(LC50) of AgNPs and CuNPs were 6.1 ppm (56.5 μM) and 2.61 ppm (41.1
μM), respectively. The number of FM1-43-labeled hair cells and the
microstructure of hair bundles were significantly impaired by AgNPs [≥1
ppm (9.3 μM)] and CuNPs [≥0.01 ppm (0.16 μM)].
Ca2+ influxes at hair bundles of hair cells were measured with a
scanning ion-selective microelectrode technique to evaluate the
function of hair cells. AgNPs [≥0.1 ppm (0.9 μM)] and CuNPs [≥0.01 ppm
(0.16 μM)] were both found to significantly reduce Ca2+ influxes.
Similar toxic effects were also found in hatched embryos subjected to 4
h of exposure (96?100 hpf) to AgNPs and CuNPs.
This study revealed that lateralline hair cells of zebrafish are
susceptible to AgNPs and CuNPs, and these contaminants in aquatic
environments could pose a threat to fish survival.
中文摘要(谷歌机翻)
纳米粒子(NPs)对鱼类早期的潜在毒性仍不清楚。在这项研究中,我们调查了银(AgNPs)和铜纳米颗粒(CuNPs)对斑马鱼胚胎侧线毛细胞的毒性作用。
斑马鱼胚胎在受精后0?96
h(hpf)的不同浓度的AgNPs和CuNPs中孵育。发现AgNPs和CuNPs均以剂量依赖性方式引起斑马鱼胚胎的毒性作用。AgNP和CuNP的96小时50%致死浓度(LC50)值分别为6.1
ppm(56.5μM)和2.61 ppm(41.1μM)。AgNPs [≥1ppm(9.3μM)]和CuNPs
[≥0.01ppm(0.16μM)]严重损害了FM1-43标记的毛细胞数量和发束的微观结构。
用扫描离子选择微电极技术测量在毛细胞的发束处的Ca 2+流入,以评估毛细胞的功能。发现AgNPs [≥0.1ppm(0.9μM)]和CuNPs
[≥0.01ppm(0.16μM)]均能显着减少Ca2 +的流入。在暴露于AgNPs和CuNPs 4小时(96?100
hpf)的孵化胚胎中也发现了类似的毒性作用。
这项研究表明,斑马鱼的侧线毛细胞对AgNPs和CuNPs敏感,而这些污染物在水生环境中可能对鱼类的生存构成威胁。
结果表明:在AgNP处理组中,相比于0 ppm,Ca2+吸收速率在0.1,1和3 ppm时分别减少了26%,46%和91%;在CuNP处理组中,相比于0 ppm,Ca2+吸收速率在0.01 ppm时减少了38%,而在0.1和1 ppm时几乎检测不到Ca2+的吸收速率。由此可见,AgNPs (≥0.1 ppm)和 CuNPs(≥0.01ppm)都会显著抑制Ca2+的吸收。海洋环境中的污染物会威胁鱼类的生存。
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
