NMT是基因功能的活体检测技术,已被103位诺贝尔奖得主所在单位,及北大、清华、中科院使用。
NMT历史上的今天
2014年01月14日,中科院水生所王强、陈辉用NMT在Plant and Cell Physiology上发表了标题为Ca2+ Signal Transduction Related to Neutral Lipid Synthesis in an Oil-Producing Green Alga Chlorella sp. C2的研究成果。'
期刊:Plant and Cell Physiology
主题:Ca2+流指示的微藻氮胁迫信号转导研究
标题:Ca2+ Signal Transduction Related to Neutral Lipid Synthesis in an Oil-Producing Green Alga Chlorella sp. C2
影响因子:4.134
检测指标:Ca2+流速
作者:中科院水生所王强、陈辉
英文摘要
Changes in the cytosolic Ca2+ levels and the role of
Ca2+ signal transduction in neutral lipid synthesis in Chlorella sp. C2
under nitrogen starvation conditions were investigated. The results
detected by using the scanning ion-selective electrode technique
demonstrate that nitrogen starvation induced significant Ca2+ influx
across the plasma membrane into cells.
Ca2+ fluorescence imaging and flow cytometry were used to estimate the
effect of this Ca2+ influx on the generation of the Ca2+ signal, and
the results showed that the cytosolic Ca2+ concentration increased
transiently and then remained at a stable, high level when the cells
were exposed to nitrogen starvation. However, the increase could be
inhibited by pre-treatment with the Ca2+ channel blockers ruthenium
red, verapamil and GdCl3, indicating that both the influx of Ca2+ from
the extracellular space via Ca2+ channels that are localized in the
plasma membrane and the release of Ca2+ from intracellular calcium
storage via the internal calcium store were required for the generation
and transduction of the Ca2+ signal.
During nitrogen starvation, neutral lipid synthesis in Chlorella sp. C2
in response to stress conditions was also inhibited to differing
degrees by pre-treatment with the three Ca2+ channel blockers,
demonstrating the regulation of Ca2+ via these Ca2+ channels in neutral
lipid synthesis.
The results suggested that by transduction of extracellular stress
signals into the cell and the regulation of the Ca2+ signal in neutral
lipid synthesis, Ca2+ signal transduction played important roles in the
response mechanism of Chlorella sp. C2 to nitrogen starvation.
中文摘要(谷歌机翻)
小球藻中胞质Ca2+水平的变化以及Ca2+信号转导在中性脂质合成中的作用。研究了氮饥饿条件下的C2。通过使用扫描离子选择电极技术检测到的结果表明,氮饥饿导致大量Ca2+穿过质膜流入细胞。
Ca2+荧光成像和流式细胞仪用于评估这种Ca2+内流对Ca2+信号生成的影响,结果表明,当细胞暴露于细胞中时,胞浆中Ca2+的浓度会瞬时增加,然后保持稳定的高水平。氮饥饿。但是,通过用Ca2+通道阻滞剂钌红,维拉帕米和GdCl3进行预处理可以抑制这种增加,这表明Ca2+经由位于质膜上的Ca2+通道从细胞外空间大量涌入以及Ca2+的释放。Ca2+信号的产生和转导需要通过内部钙储存器进行细胞内钙储存。
在氮饥饿期间,小球藻中的中性脂质合成。通过使用三种Ca2+通道阻滞剂的预处理,C2对应激条件的响应也受到了不同程度的抑制,这表明在中性脂质合成中通过这些Ca2+通道对Ca2+的调节。
结果表明,通过将细胞外应激信号转导到细胞中以及中性脂质合成中Ca2+信号的调节,Ca2+信号转导在小球藻的反应机制中发挥了重要作用。C2导致氮饥饿。
Fig. 1 The total Ca2+ ?ux rates over 5 min in Chlorella sp. C2 under N starvation. (a) Microphotographic examples of Ca2+ ion ?ux/voltage-clamp measurements. (b) Total ?ux rates of Ca2+ were detected at 0, 0.5, 2 and 8 d after N starvation. The columns represent the means of three replicated studies in each sample, with the SD of the means (t-test, P < 0.05). The signi?cance of the differences between the control (0 d) and other test values was tested using a one-way analysis of variance. *P < 0.05 vs. control.
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
