NMT作为生命科学底层核心技术,是建立活体创新科研平台的必备技术。2005年~2020年,NMT已扎根中国15年。2020年,中国NMT销往瑞士苏黎世大学,正式打开欧洲市场
NMT历史上的今天
2016年05月13日,中国农业大学王忠义用NMT发表了标题为The calibration model in potassium ion flux non-invasive measurement of plants in vivo in situ的研究成果。
期刊:Information Processing in Agriculture
主题:非损伤NMT设备检测K+流的稳定性
标题:The calibration model in potassium ion flux non-invasive measurement of plants in vivo in situ
检测指标:K+流速
作者:中国农业大学王忠义
英文摘要
NMT (Non-invasive Micro-test Technology) provides a
novel electrophysiological tool which can non-invasively measure the
dynamic influxes and effluxes of ions caused by the diffusion along the
concentration gradients in vivo.
However, in this technique ion fluxes are converted to voltage signals
using an ion selective microelectrode at a small amplitude of μV, which
is easy to be interfered by the ambient noise. Hence, effective
solutions to the suppression of noise and calibration of ion flux
measurement system are very important for this method. A K+-selective
microelectrode was constructed using liquid ion exchangers (LIX) to
investigate ion transport over plant tissue.
A standard concentration gradient which simulates plant living cells
was produced by an electrode with a certain tip diameter, filled with a
solution containing a known K+ concentration in 100 mmol/L. An ion
diffusion simulation model was established. This model evaluated the
performance of ion flux measurement system in accuracy and reliability
by comparing the consistency of the measured value and the predicted
curve. K+ fluxes were measured within 25 minutes at each measuring
point of distance 10, 20, 30, 40, 50, 80, and 100 μm from the K+
source, respectively.
It can be seen that the K+ fluxes changes little, which indicates that ion fluxes measurement system has a reliable stability. The study provides a theoretical basis for a new non-invasive ion flux measurement method creation and a new sensors design.
中文摘要(谷歌机翻)
NMT(非损伤微测技术)提供了一种新型的电生理工具,可以无创地测量由于体内浓度梯度的扩散所引起的离子的动态流入和流出。
然而,在该技术中,使用离子选择微电极以小幅度的μV将离子通量转换为电压信号,这容易受到环境噪声的干扰。因此,有效的解决方案包括抑制噪声和校准离子通量测量系统。使用液体离子交换剂(LIX)构建K+选择性微电极,以研究离子在植物组织上的传输。
由具有一定尖端直径的电极产生的模拟植物活细胞的标准浓度梯度,该电极填充有含有100 mmol /
L已知K+浓度的溶液。建立了离子扩散模拟模型。该模型通过比较测量值和预测曲线的一致性来评估离子通量测量系统在准确性和可靠性方面的性能。在25分钟内分别在距K
+源10、20、30、40、50、80和100μm的每个测量点测量K+通量。
可以看出,K+通量变化很小,表明离子通量测量系统具有可靠的稳定性。该研究为新的非侵入式离子通量测量方法的创建和新的传感器设计提供了理论基础。
Fig. 8. K+ flux measured at each known position (vibration amplitude Δx is 10
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
