NMT作为生命科学底层核心技术,是建立活体创新科研平台的必备技术。2005年~2020年,NMT已扎根中国15年。2020年,中国NMT销往瑞士苏黎世大学,正式打开欧洲市场。
研究使用平台:NMT生物膜创新科研平台
期刊:Science of the Total Environment
主题:抑制钾信号影响地杆菌生物膜的形成
标题:Potassium channel blocker inhibits the formation and electroactivity of Geobacter biofilm
影响因子:5.589
检测指标:K+流速
检测样品:地杆菌
K+流实验处理方法:
地杆菌分别在0mM、5mM、10mM的TEA中处理
K+流实验测试液成份:
0.1mM KCl、1mM glucose
作者:福建农林大学陈姗姗、靖宪月
中文摘要(谷歌机翻)
生物膜中的细菌能够利用钾离子通道介导的电信号来实现细胞间的通信。然而,目前尚不清楚当被强电场包围时,这些信号是否在Geobacter sp。中起作用。
这项研究使用了钾通道阻滞剂(四乙铵,TEA),该阻滞剂干扰K+的释放,但不干扰细菌的生长,以证明钾离子通道介导的电信号传导影响了Geobacter
sulfreducens的形成和电活性。结果表明,5 mM TEA减慢了地球还原硫细菌生物膜的形成,电流密度比对照组低约50%。
电化学分析表明,加入TEA的生物膜的电活性较差。特别是,具有TEA的微米级生物膜表现出较少的高电流峰,并且参与还原性减少硫杆菌的生物膜中电子转移的最外层基团的物种与对照组不同。
这项工作提供了初步的证据来揭示钾通道在还原性土壤杆菌中的电活性生物膜的作用。
Mean net K+ fluxmeasured from the biofilms in response to treatment with 5 mM
英文摘要
Bacteria in biofilms are able to utilize potassium
ion channel mediated electrical signaling to achieve cell–cell
communication. However, it remains unclear whether these signals play a
role in Geobacter sp.when surrounded by an intense electric field.
This study used a potassium channel blocker (tetraethylammonium, TEA)
that interfered with the release of K+ but not bacterial growth to
demonstrate that potassium ion channel-mediated electrical signaling
affected the formation and electroactivity of Geobacter sulfurreducens.
The results showed that 5 mM TEA slowed the formation of Geobacter
sulfurreducens biofilm, and the current density was ~50% lower than in
the control.
The electrochemical analyses showed that the electroactivity of the
biofilms with TEA addition was inferior. In particular, the micrometer-
scale biofilm with TEA exhibited fewer high current peaks, and the
species of outermost groups that participated in the electron transfer
in Geobacter sulfurreducens biofilms was different from the control.
This work provides initial evidence to reveal the role of potassium channels in Geobacter sulfurreducens electroactive biofilms.
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
