中瑞祥凝胶化时间测试仪 型号ZRX-30880
用途 Usage:
用于覆铜板和线路板行业测试半固化片及树脂的凝胶化时间的仪器设备。
It is a special instruments that used for testing gel time of prepreg and resin in CCL and PCB industry.
 特征 Features
采用 OMRON 温控器,数字式显示,PID 控制,对胶池温度进行精确控制,精度可达±0.5℃
It adopts temperature control of ORMONdigital display and PID control which can precisely control temperature of gum
pond,with control accuracy of±5 ℃
计时精确,最小分辩率为 0.1s
The time record is accurate, and the minimum resolution is 0.1S. 采用可靠的过流、漏电保护装置,提高操作安全性。
It improved operational security through adopting reliable current and earth leakage protection devices. 操作简单方便,左右设计两个 START/STOP 控制按钮,适应左右手习惯不同实验操作人群。
The operating is simple and convenient, designed with two start/stop control buttons in left and right side, which is adaptable for different experimental groups who have different habits to use either hand. 5.硕大 LED 液晶数字显示,外观新颖美观。
It is equipped with large LCD digital display, the appearance is new and elegant. 技术参数 Technical Parameter:
项目 item 规格 specification
计时范围 time range 0999.9s
温度调节范围 temprerature adjustable range 0230℃
控 制 温 度 精 度 temprerature control accuracy
±0.5℃
电源要求 power requirement 220V/50Hz 功率 power 300W
胶池尺寸 glue-pond dimension Φ20mm 外形尺寸 appearance dimension 350×430×550mm 重量 weight 20kg
阅读13次
最新动态
推荐产品
当前位置: 中瑞祥 动态 中瑞祥凝胶化时间测试仪 型号ZRX-30880
