方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 聚合物复合材料 |
For many modern technical applications, polymer composites are the materials of choice because their properties like e.g. specific strength, chemical resistance and shape can be tailored to the individual application. The production process involves embedding fibres or fibre fabrics in a liquid polymer matrix. Subsequently, to control this process, the rheological characterization of the liquid matrix is a must. To test the mechanical properties of the final composite is at least difficult if not impossible with classical rheological setup. Due to the high hardness and smooth surface of many composites, samples are difficult to shape and often slip after being put between parallel plates
衣物柔顺剂的稳定性分析
原研药与仿制药的加速稳定性分析
利用CAT(离心粘结力测试)技术定量测定胶带性能
LUMiFrac稳定性分析仪
LUMiReader X-Ray分散体系分析仪
LUMiReader PSA稳定性分析仪
LUMiFuge稳定性分析仪
LUMiSizer稳定性分析仪
LUMiFlector牛奶分析仪
HAAKE PolyLab QC 模块化转矩流变仪
HAAKE PolyLab OS 模块化转矩流变仪
STEPHAN Combitherm真空搅拌器
STEPHAN Cook-It搅拌器
STEPHAN Vacutherm真空搅拌器
Stephan UM 70/130/200真空搅拌器
Stephan UM 24–74搅拌器
Stephan UMSK 24–60E真空搅拌器
Stephan UM 5–12 搅拌器
