Salinity ofSaline Solution Salinity ofSaline Solution Star SeriesMethod Note M-1809-E03/05 RevB Salinity ofSaline Solution Analysis · Chloride Introduction 1. Place the chloride electrode and stirrer into the beaker with sample such that the electrode tip is fullyimmersed in the solution. The stirrer should be positioned slightly below the tip of the electrode.Press the STIRRER key on the meter to turn the stirrer on. 2.Wait for stable reading (1-2 minutes). Record the electrode potential. This method provides uncomplicated determination of the salinity of the saline solution by measuringchloride ion concentration using Known Addition technique and ion selective chloride electrode.Known Addition is a technique of adding a small aliquot of the standard of interest to the sample, andcalculating the original sample concentration from the observed change in potential. 3. Pipette 10 mL of standard into the beaker. 4.Wait for stable reading (1-2 minutes). Record the electrode potential. ·Saline solution·Orion ionplus@Sure-Flow@Combination lonSelective ChlorideElectrode (ISE) 5. Press the STIRRER key to turn the stirrer off. 6.Subtract the first reading from the second to find AE. 7. From the table in Results section, find the value, Q, which corresponds to the change in potential. 8. Repeat steps 1-7 for additional samples. Remember, rinse electrodes with deionized water between measurements. Upon completion of samples,rinse the electrode with deionized water and store the electrode according to instructions in the ElectrodeStorage section of this method note. 6. Beakers (150 mL) 7. Pipettes (2 mL, 5 mL, 10 mL) 3. Orion benchtop stirrer (or magnetic stir plate and bar) 096019 Required Solutions Cat. No. 1. 0.1 M Sodium Chloride Standard 941706 2. ISA (Ionic Strength Adjuster ) for chloride electrode 940011 3. Reference Filling Solution, Optimum Results" B 900062 4. Deionized water. Standard Preparation 1. All samples and standard should be at room temperature. Use a quantity of 0.1 M Sodium ChlorideStandard Solution that, upon addition to the sample, will cause the concentration of the chloride ionto approximately double. Maximum precision will be obtained from a change in reading from about10 mv to about 32 mv. Sample Preparation 1. Pipette 5 mL of saline solution into 100 mL volumetric flask. Dilute to the mark with deionizedwater.Add 2mL ISA. Mix well. 2. Repeat this procedure for measurements on additional samples. Registered Environmental InstrumentsWater Analysis Instruments166 Cummings CenterBeverly, MA 01915 USAM1809E03/05ieYi250312-001 Toll Free:1-800-225-1480Tel:1-978-232-6000Dom. Fax:1-978-232-6015Intl Fax:978-232-6031www.thermo.com/waterO 2005 Thermo Electron Corporation ISO 9001:2000 All rights reserved Results Three samples of saline solution were analyzed using a single known addition method. Chloride concentrationwas calculated using the formula bellow: Csam =Q*Cstd *D Where: Cstd = standard concentration Csam=sample concentration Qnown addition table* =reading from kD = dilution factor *The table of Q values is calculated for a 10%volume change for electrodes with slope of 58 mV. The equationfor the calculation of Q for different slopes and volume changes is given in the instruction manual for Orionchloride electrode, Orion 94-17 and Orion 96-17. Refer to Table 4 in the electrode instruction manual. Below an example of calculation for a sample #1: First mV reading-64.9 mV Second mV reading-35.9 mV △E=64.9-35.9=29 mV The value, Q, which corresponds to the change in potential =0.0394 Csam, M=0.0394*0.1*20=0.079 Csam, %=0.079*35.45/10=0.28 Saline Solution M Chloride % Chloride Sample#1: 0.079 0.28 Sample #2: 0.075 0.27 Sample#3: 0.077 0.27 Mean: 0.077 0.27 Standard Deviation: 0.002 0.006 % CV 2.60 2.11 Electrode Storage The solution in the electrode should not be allowed to evaporate, causing crystallization. For short periods oftime, between sample measurements, and up to one week, store the electrode in 0.01M chloride standard.For storage longer than one week or for an indefinite period, drain the electrode. Flush the inside with distilledwater and store dry with the protective cap to protect the sensing element. Electrode Setup 1. Remove the rubber cap covering the electrode tip. 2. Fill outer chamber with Optimum Result B filling solution. 3. Lift the filling solution bottle’s spout to a vertical position. 4 Insert the spout into the filling hole in the outer sleeve of the electrode and add a small amount of fillingsolution to the chamber. Then tip the electrode to moisten the o-ring at the top and return electrode to avertical position. 5. Holding the electrode by the barrel with one hand, use the thumb to push down on the electrode cap,allowing a few drops of filling solution to drain wetting the inner cone. 6. Release sleeve. 7. If sleeve does not return to its original position immediately, check to see if the o-ring is moist and repeat steps4-6 until the outer sleeve has returned to its original position. Add filling solution just bellow the fill hole. Meter Setup For initial meter setup please follow the steps in the Quick Start Guide which is attached to the meter itself.The Quick Start Guide also contains a layout of the meter keyboard for reference. Please note words in allcapitals such as POWER indicate a key on the meter, and words in quotations such as “Unitindicate a displayon the meter screen. 1. Connect the electrode to the meter.2.. Connect the stirrer to the meter. 3 Press the POWER key on the meter to turn the meter on. 4. Note that the arrow on the left of the screen indicates the active line. If the top line is not active, press theLINE SELECTION key to change the selected line to the top line. Then press the UP or DOWN arrowkeys to change the measurement mode of the top line to mV. 5. Press the MEASURE key to return to the measurement mode. If all steps were followed correctly the meter display will show "mV" to the right of the top line. The meter andelectrode are now ready for measurement. Note: The Orion Benchtop Stirrer must be turned on in General Instrument Setup before analysis, please see the QuickstartGuide for instructions. www.thermo.com of of of f
关闭产品配置单
赛默飞中国实验室产品事业部为您提供《盐溶液中盐度的测定》,该方案主要用于其他中null检测,参考标准《暂无》,《盐溶液中盐度的测定》用到的仪器有台式pH/ORP/ISE/溶解氧/电导率测量仪、Orion 4-Star台式(便携式)pH/离子浓度测量仪。
