氢气和甲烷中相对喷嘴结构氢气和甲烷边界和扩散火焰:结构和稳定性检测方案(流量计)
检测样品
其他
检测项目
关联设备
共3种
下载方案
Hydrogen/air and methane/air flames in axi-symmetric opposed jet burners were investigated
experimentally for different flow velocities, burner geometries and fuel dilutions.
Above critical strain rate values there is the local extinction of the planar diffusion flame,
and the edge flame forms, which propagates and stabilizes further away from the axis
of symmetry, assuming a toroidal shape. The ranges of air and fuel flow velocities over
which the diffusion or the edge flame are stable were determined. There is a substantial
range over which both flames can be stabilized, and the transition between the two flame
types exhibits a strong hysteresis.
Raman spectroscopy was used for the determination of the spatial distribution of
temperature and major species concentrations, while the OH radical distribution was
obtained with Planar Laser Induced Fluorescence (LIF). Particle Image Velocimetry (PIV)
was employed to characterize the flow fields both in cold and reactive conditions.
北京欧兰科技发展有限公司为您提供《氢气和甲烷中相对喷嘴结构氢气和甲烷边界和扩散火焰:结构和稳定性检测方案(流量计)》,该方案主要用于其他中相对喷嘴结构氢气和甲烷边界和扩散火焰:结构和稳定性检测,参考标准《暂无》,《氢气和甲烷中相对喷嘴结构氢气和甲烷边界和扩散火焰:结构和稳定性检测方案(流量计)》用到的仪器有PLIF平面激光诱导荧光火焰燃烧检测系统、Imager sCMOS PIV相机、德国LaVision PIV/PLIF粒子成像测速场仪。
我要纠错
