流化床中碰撞特性对喷动流化床动力学影响的实验研究检测方案(粒子图像测速)
检测样品
其他
检测项目
关联设备
共1种
下载方案
In this paper we experimentally study the effect of collision properties of
different particle systems on the bed dynamics of a spout fluidized bed. This
is done for different flow regimes: the spout-fluidization regime (case A), the
jet-in-fluidized-bed regime (case B) and the spouting-with-aeration regime
(case C). The considered particle systems comprise glass beads,
-alumina
oxide and zeolite 4A particles, which are all classified as Geldart D. A nonintrusive
measurement technique is used, viz. particle image velocimetry
(PIV) to measure the particle flow field in a pseudo two-dimensional (2D)
spout fluidized bed. Additionally, digital images are analyzed using a newly
developed digital image analysis (DIA) algorithm to evaluate the particle
volume fraction. It is demonstrated that the new proposed DIA algorithm
provides reliable information on the particle volume fraction distribution,
showing that it is a powerful tool when combined with PIV. The added value
of DIA is confirmed by comparing the particle velocity fields and volumetric
particle fluxes. The effect of the collision properties for glass beads,
alumina oxide and zeolite 4A particles has been studied in three flow regimes,
i.e. the intermediate/spout-fluidization regime (case A), the jet-in-fluidizedbed
regime (case B) and the spouting-with-aeration regime (case C). For each flow regime, the particle volume fraction shows small differences between
the different particle systems. For the
-alumina oxide and zeolite 4A
particles, the spout channel is less stable for the cases A and C. The particle
fluxes display also small differences between the particle systems for each
flow regime.
北京欧兰科技发展有限公司为您提供《流化床中碰撞特性对喷动流化床动力学影响的实验研究检测方案(粒子图像测速)》,该方案主要用于其他中碰撞特性对喷动流化床动力学影响的实验研究检测,参考标准《暂无》,《流化床中碰撞特性对喷动流化床动力学影响的实验研究检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪。
我要纠错
