Active flow control of jets with Localized Arc Filament Plasma Actuators (LAFPAs) is conducted over a
wide range of the fully expanded jet Mach numbers (MJ or simply jet Mach number). The jet Mach
numbers covered in the present research are 0.9 (with a converging nozzle), 1.2 (overexpanded), 1.3
(perfectly expanded), and 1.4 (underexpanded) with a design Mach number 1.3. Additionally, limited
experiments are carried out for an MJ = 1.65 perfectly-expanded jet. The exit diameter is 2.54 cm (1 inch)
for all cases and eight LAFPAs are equally distributed on the perimeter of a boron nitride nozzle
extension. The jet spreading is strongly dependent on duty cycle, forcing frequency, and azimuthal modes.
The performance of LAFPAs for jet spreading is investigated using two-dimensional particle image
velocimetry (PIV). There is an optimum duty cycle, producing maximum jet spreading, for each forcing
frequency. A relationship between the optimum duty cycle and forcing frequency is determined from the
extensive results in the MJ 0.9, and this relation is used for all experiments. The effect of forcing
frequency is investigated for a wide range of forcing Strouhal numbers (StDF = fFD/Ue, where fF, D, and
Ue, are forcing frequency, nozzle exit diameter, and jet exit velocity respectively), ranging from 0.09 to
3.0. The azimuthal modes (m) investigated are m = 0 – 3, ±1, ±2, and ±4 - this comprises all modes
available with eight actuators. The performance of LAFPAs does also strongly depend on the stagnation
temperature of the jet and MJ. The effects of stagnation temperature are investigated for 1.0, 1.4, and 2.0
times the ambient temperature in MJ 0.9 jet for very limited azimuthal modes and StDF. In an MJ 1.65
perfectly-expanded jet, the control authority of LAFPAs is investigated for only m = ±1 and StDF ∼ 0.3.
北京欧兰科技发展有限公司为您提供《流体中速度场检测方案(粒子图像测速)》,该方案主要用于其他中速度场检测,参考标准《暂无》,《流体中速度场检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、Imager LX PIV相机。
