流体中2D3C速度矢量场,时间分辨速度矢量场检测方案(粒子图像测速)
检测样品
其他
检测项目
2D3C速度矢量场,时间分辨速度矢量场
关联设备
共2种
下载方案
In the last years, several techniques have been developed and improved in such a way that it is
possible to measure the three velocity components in a flow. Some techniques as Stereoscopic PIV or
holographic PIV are well known. Others, like tomographic PIV started to develop more recently.
Stereoscopic Particle Image Velocimetry (SPIV) or Tomographic PIV need a complex set-up, involving flow
visualization with several cameras, and present important restrictions when applied to confined liquid flows.
Others like Holographic PIV cannot be applied in flows with a high particle density. Here a new technique,
called High Speed Digital Image Plane Holography has been developed for the measurement of the three
velocity components in a complex geometry brain aneurysm model using a configuration similar to regular
PIV. This was done by using a two cavity high speed laser, one double frame high speed camera and normal
visualization. The two in-plane velocity components were obtained from the holograms reconstructed
intensity distribution using a PIV analysis. The out-of plane component was obtained from the reconstructed
phase differences using an interferometric method. Due to the laser short coherence length, a portable and
compact system has been built in order to be able to the measure larger fluid areas.
北京欧兰科技发展有限公司为您提供《流体中2D3C速度矢量场,时间分辨速度矢量场检测方案(粒子图像测速)》,该方案主要用于其他中2D3C速度矢量场,时间分辨速度矢量场检测,参考标准《暂无》,《流体中2D3C速度矢量场,时间分辨速度矢量场检测方案(粒子图像测速)》用到的仪器有时间分辨粒子成像测速系统(TR-PIV)、LaVision HighSpeedStar 高帧频相机。
我要纠错
