铝合金中高速加工产生的残余应力和温度与刀具参数的关系效应研究检测方案(粒子图像测速)
检测样品
合金
检测项目
关联设备
共1种
下载方案
The need throughout the machining industry for cost reduction and increases
in productivity have contributed to new interest in high-speed machining. Even
though, many model for machining exist, most of them are for low-speed machining,
where momentum is negligible and material behavior is well approximated by
the quasi-static laws. In machining at high speeds momentum could be large and the
strain rate can be exceedingly high. For these reasons a
uid mechanics approach
to understanding high-speed, very high-speed and ultra-high-speed machining is attempted
here.
北京欧兰科技发展有限公司为您提供《铝合金中高速加工产生的残余应力和温度与刀具参数的关系效应研究检测方案(粒子图像测速)》,该方案主要用于合金中高速加工产生的残余应力和温度与刀具参数的关系效应研究检测,参考标准《暂无》,《铝合金中高速加工产生的残余应力和温度与刀具参数的关系效应研究检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪。
我要纠错
