柴油发动机中NO的激光诊断检测方案(尾气检测)
检测样品
汽车电子电器
检测项目
NO的激光诊断
关联设备
共1种
下载方案
In 1897 Rudolf Diesel (1858-1913) demonstrated a new type of internal combustion (i.c.)
engine in which the high compression pressure of about 35 times the atmospheric pressure
led to a sufficiently high temperature to cause the auto-ignition of kerosine. Ever since
diesel engines remained popular owing to their relatively high efficiencies and their ability
to combust a large variety of fuels predominantly containing heavier crude oil components
(i.e., longer aliphatic hydrocarbon chains). The original engines were 4-stroke engines in
which one complete engine cycle takes two revolutions of the crank shaft. The latter
transforms the translational energy of the piston in the cylinder into more convenient
rotational energy with respect to vehicle propulsion. As schematically depicted in figure
1.1, in the first stroke the piston moves downwards in the cylinder and ambient air is
taken in above the piston (inlet stroke). In the second stroke the inlet valve is closed and
the piston moves upwards compressing the intake air (compression stroke). Just before the
piston reaches its Top Dead Centre (TDC) fuel is sprayed in the combustion chamber and
combustion takes place driving the piston downwards again in the third stroke (expansion
stroke). Finally, the exhaust valve opens and the piston moves upwards again in the fourth
stroke (exhaust stroke) pushing the combustion gases out of the cylinder. In later years 2-
stroke diesel engines were developed in which, by using the space of the crank case below
the piston as well, the work usually done in four strokes is now performed by one
revolution of the crank shaft. Around 1940 the first turbo-charging diesel engines were
developed in which the energy contained in the exhaust gases is used to compress the
intake air in order to boost the power of the engines.
北京欧兰科技发展有限公司为您提供《柴油发动机中NO的激光诊断检测方案(尾气检测)》,该方案主要用于汽车电子电器中NO的激光诊断检测,参考标准《暂无》,《柴油发动机中NO的激光诊断检测方案(尾气检测)》用到的仪器有汽车发动机多参量测试系统。
我要纠错
