搅拌槽中流体力学和喷射注入研究检测方案(粒子图像测速)
检测样品
其他
检测项目
流体力学和喷射注入研究
关联设备
共1种
下载方案
To quench a thermal runaway reaction in a chemical rector, an efficient approach is the introduction of a small quantity of a liquid inhibiting agent, named a “killer”, into the mixing
vessel. In this thesis, an experimental approach has been coupled tightly with numerical modelling using Computational Fluid Dynamics (CFD). The first part of this thesis is devoted to a study of the hydrodynamics of partially-baffled mixing vessels, including the free-surface deformation caused by the central vortex. The use of an inhomogeneous, multiphase approach allowed simulation of the free-surface deformation. The capability of this novel method was
demonstrated by very good agreement between the numerical predictions and experimental data. In the second part, liquid jet injection at the free-surface was coupled with the vessel hydrodynamics. Numerical results, obtained using an Eulerian-Lagrangian approach, have again shown good agreement with experimental data. These results allowed the jet trajectory to be modelled and its penetration into the agitated vessel was quantified. New mixing criteria were introduced that are specific to this application. Finally, the numerical methods validated at the pilot scale were applied at the industrial scale and allowed the proposal of practical improvements to the safety of the synthesis reactors studied.
北京欧兰科技发展有限公司为您提供《搅拌槽中流体力学和喷射注入研究检测方案(粒子图像测速)》,该方案主要用于其他中流体力学和喷射注入研究检测,参考标准《暂无》,《搅拌槽中流体力学和喷射注入研究检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪。
我要纠错
