泥岩中自由上表面水饱和模型实验结果检测方案(粒子图像测速)
检测样品
其他
检测项目
自由上表面水饱和模型实验结果
关联设备
共2种
下载方案
The aim of this study is to improve our knowledge of the processes that lead to clay smear during faulting of
a layered sand-clay sequence in an analogue sandbox model. We carefully characterized mechanical properties of the
materials used by a series of geotechnical tests. Displacement field was quantified using PIV (Particle Image Velocimetry).
The model is water-saturated to allow the deformation of wet clay and sand in one experiment comprising a sand
package with a horizontal layer of clay above a predefined rigid basement fault. The thickness and rigidity of the clay
layer are the parameters varied in this study. The model shows a range of structures that are related to competence
contrast between sand and different clay types. Results show ductile shearing of soft clay with a transition to brittle
fracturing of stiff clay accompanied by the formation of rotating clay blocks in the fault zone. Localized deformation is
observed through time showing (i) the propagation of one active fault migrating laterally through the sediment package,
and (ii) the formation of a stable prism between two or more active faults that gets progressively smaller with minor
rotation of the hanging wall fault. Continuous clay smear is observed resulting from the lateral injection of clay as well
as from a reworked mixture of sand and clay.
北京欧兰科技发展有限公司为您提供《泥岩中自由上表面水饱和模型实验结果检测方案(粒子图像测速)》,该方案主要用于其他中自由上表面水饱和模型实验结果检测,参考标准《暂无》,《泥岩中自由上表面水饱和模型实验结果检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、LaVision StrainMaster材料应变形变成像测量系统。
我要纠错
