雾沫中致冷空气幕墙的雾沫夹带现象研究检测方案(粒子图像测速)
检测样品
其他
检测项目
致冷空气幕墙的雾沫夹带现象研究
关联设备
共1种
下载方案
Refrigerated air curtains are used in supermarket display cases to keep warm ambient air from entering the
refrigerator case. Entrainment of ambient air into the curtain by shear layer mixing contributes to both the sensible
and the latent heat load on the cases. In order to reduce this entrainment, a closer look at the air curtain is undertaken
here. Particle Image Velocimetry was used to examine idealized air curtains of various Reynolds and Richardson
numbers. The air curtain entrainment was seen to be dominated by eddies that engulfed ambient air into the air
curtain. For the isothermal (Ri=0) curtains, it was observed that the air curtain dynamics and entrainment were not
sensitive to Reynolds number variation between Re=3800 and Re=8500. At low air velocities (Re=1500), the curtain
was found to detach, leading to extremely high entrainment rates. Variations in Richardson number of the curtain
affected the flow at the curtain inlet most dramatically, where the acceleration of gravity caused the curtain to neck
inwards. The overall thermal entrainment was shown to reduce with reducing Reynolds number, implying that a
reduction in air curtain entrainment could be achieved by reducing the air velocity of the curtain, as long as air
curtain integrity is maintained.
北京欧兰科技发展有限公司为您提供《雾沫中致冷空气幕墙的雾沫夹带现象研究检测方案(粒子图像测速)》,该方案主要用于其他中致冷空气幕墙的雾沫夹带现象研究检测,参考标准《暂无》,《雾沫中致冷空气幕墙的雾沫夹带现象研究检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪。
我要纠错
