当前位置: 其他 > 方案详情
流体中3D3C速度场检测方案
检测样品 其他
检测项目 3D3C速度场
关联设备 共3种 下载方案
方案详情
A novel technique to increase the accuracy of multiplicative algebraic reconstruction technique (MART) reconstruction from tomographic particle image velocimetry (PIV) recordings at higher seeding density than currently possible is presented. The motion tracking enhancement (MTE) method is based on the combined utilization of images from two or more exposures to enhance the reconstruction of individual intensity fields. The working principle is first introduced qualitatively, and the mathematical background is given that explains how the MART reconstruction can be improved on the basis of an improved first guess object obtained from the combination of non-simultaneous views reduced to the same time instant deforming the 3D objects by an estimate of the particle motion field. The performances of MTE are quantitatively evaluated by numerical simulation of the imaging, reconstruction and image correlation processes. The cases of two or more exposures obtained from time-resolved experiments are considered. The iterative application of MTE appears to significantly improve the reconstruction quality, first by decreasing the intensity of the ghost images and second, by increasing the intensity and the reconstruction precision for the actual particles. Based on computer simulations, the maximum imaged seeding density that can be dealt with is tripled with respect to the MART analysis applied to a single exposure.
关闭
产品配置单
北京欧兰科技发展有限公司为您提供《流体中3D3C速度场检测方案 》,该方案主要用于其他中3D3C速度场检测,参考标准《暂无》,《流体中3D3C速度场检测方案 》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、时间分辨粒子成像测速系统(TR-PIV)、体视层析粒子成像测速系统(Tomo-PIV)。
我要纠错
推荐专场
相关方案
