水喷射泵转子叶片中尖区流场结构的可视化研究检测方案(粒子图像测速)
检测样品
其他
检测项目
尖区流场结构的可视化研究
关联设备
共2种
下载方案
In this paper, we examine the occurrence of cavitation
in the tip region of a waterjet pump, and use the
observations to identify key features of the flow
structure. The rotor, stator and pump casing in our
recently upgraded facility are made of acrylic, whose
refractive index matches that of the working fluid, a
concentrated aqueous solution of sodium iodide. Such
matching makes the blades invisible, enabling flow
structure visualization and optical measurements
without any obstructions. Our initial tests with fresh
water focus on cavitation in the vicinity of the tip
region close to design conditions. Near the leading
edge, cavitation inception near the tip corner of the
pressure side causes accumulation of bubbles along the
pressure side of the corner until mid blade. As roll-up
of the tip leakage vortex (TLV) starts in the mid blade
region, these bubbles travel across the tip-clearance to
the suction side, and become nuclei for cavitation
inception in the TLV. As the TLV migrates to the
vicinity of the pressure side of the neighboring blade it
bursts, generating a cloud of bubbles that spreads over
most of the aft section of the passage. The leakage flow
in the tip gap along the aft side of the blade is strong
enough to cause sheet cavitation within the gap,
starting from the pressure side corner. The paper also
presents preliminary Particle Image Velocimetry (PIV)
data concentrating on the roll-up of TLV. Results are
consistent with observed cavitation phenomena.
北京欧兰科技发展有限公司为您提供《水喷射泵转子叶片中尖区流场结构的可视化研究检测方案(粒子图像测速)》,该方案主要用于其他中尖区流场结构的可视化研究检测,参考标准《暂无》,《水喷射泵转子叶片中尖区流场结构的可视化研究检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、三维立体PIV。
我要纠错
