流场中3D3C速度矢量场检测方案(粒子图像测速)
检测样品
其他
检测项目
3D3C速度矢量场
关联设备
共3种
下载方案
The Tomographic-PIV measurement system performances are experimentally assessed within the present
study. The technique is applied to the turbulent air flow past circular cylinders in two configurations, namely the
thin light sheet and the thick light sheet. In the first case the Tomo-PIV measurements are compared with
stereoscopic PIV, which is assumed as a reference result. Image signal conditioning by pre-processing seems to be
essential in order to achieve an accurate particle field reconstruction in presence of background light and electronic
noise. The comparison shows that the two techniques are basically equivalent in the thin light sheet configuration.
The 3D measurements are performed with the thick light sheet technique where the instantaneous velocity vector
distribution is measured over a domain of 31x26x10 mm3 yielding 28x24x5 velocity vectors. The vortex wake past a
circular section cylinder is visualized within the volume snapshots and the time-averaged flow representation shows
a consistent flow pattern with respect to the geometric boundary conditions with the separated shear layers aligned
along the cylinder axis.
北京欧兰科技发展有限公司为您提供《流场中3D3C速度矢量场检测方案(粒子图像测速)》,该方案主要用于其他中3D3C速度矢量场检测,参考标准《暂无》,《流场中3D3C速度矢量场检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、体视层析粒子成像测速系统(Tomo-PIV)、Imager sCMOS PIV相机。
我要纠错
