流体中PLIF,平面激光诱导荧光,浓度场,速度场检测方案(流量计)
检测样品
其他
检测项目
关联设备
共3种
下载方案
A concept for dynamic mixture formation
investigations of fuel/air mixtures is presented which can
equally be applied to several other laser induced fluorescence
(LIF) applications. Double-pulse LIF imaging was
used to gain insight into dynamic mixture formation processes.
The setup consists of a modified standard PIV setup.
The ‘‘fuel/air ratio measurement by laser induced fluorescence
(FARLIF)’’ approach is used for a quantification of the
LIF images in order to obtain pairs of 2D fuel/air ratio maps.
Two different evaluation concepts for LIF double pulse
images are discussed. The first is based on the calculation of
the temporal derivative field of the fuel/air ratio distribution.
The result gives insight into the dynamic mixing process,
showing where and how the mixture is changing locally. The
second concept uses optical flow methods in order to estimate
the motion of fluorescence (i.e., mixture) structures to
gain insight into the dynamics, showing the distortion and
the motion of the inhomogeneous mixture field.
北京欧兰科技发展有限公司为您提供《流体中PLIF,平面激光诱导荧光,浓度场,速度场检测方案(流量计)》,该方案主要用于其他中PLIF,平面激光诱导荧光,浓度场,速度场检测,参考标准《暂无》,《流体中PLIF,平面激光诱导荧光,浓度场,速度场检测方案(流量计)》用到的仪器有PLIF平面激光诱导荧光火焰燃烧检测系统、德国LaVision PIV/PLIF粒子成像测速场仪、汽车发动机多参量测试系统。
我要纠错
