翼型中流场,声学特性检测方案
检测样品
其他
检测项目
流场,声学特性
关联设备
共3种
下载方案
The rod-airfoil con痝uration is a benchmark test case for aeroacoustic assessments of vortex-
structure interaction noise. Several industrial devices are arranged in such a way that down-
stream bodies are embedded in the wake of upstream bodies, such as gas turbines, high lift
devices, helicopters among others. Aeroacoustic predictions usually rely on time dependent
皁w 痚ld information obtained from CFD for the determination of the aeroacoustic sources.
The present work proposes a novel approach for the aeroacoustic prediction of rod-airfoil noise
based on time-resolved PIV experimental data.
The aeroacoustic emission of a NACA0012 airfoil in the Karman wake of a rod is investigated
by means of 2D TR-PIV in combination with beamforming and microphone measurements.
First the time evolving velocity 痚ld around the airfoil is measured using high-speed PIV.
The corresponding pressure 痚ld is then deduced by spatial integration of a Poisson-based
algorithm for quasi-2D incompressible 皁ws. Pressure and velocity computed on speci痗
surfaces around the airfoil constitute the source terms of the implemented Curle's and Ffowcs
Williams-Hawkings's aeroacoustic analogies. The calculated Sound Pressure Level (SPL) is
compared with the measurements obtained by far 痚ld microphones. Velocity visualizations
in the spanwise direction provide qualitative information about the phase coherence of the
vortical impingement along the airfoil span. Parametric studies are performed to evaluate the
e甧ct on the acoustic prediction of the position of the integration surface and the numerical
discretization methods employed.
北京欧兰科技发展有限公司为您提供《翼型中流场,声学特性检测方案 》,该方案主要用于其他中流场,声学特性检测,参考标准《暂无》,《翼型中流场,声学特性检测方案 》用到的仪器有自适应粒子成像测速场仪(PIV)、德国LaVision PIV/PLIF粒子成像测速场仪、时间分辨粒子成像测速系统(TR-PIV)。
我要纠错
